 6.2K     0
One key consideration - the used locos they are buying are exact carbon copies of the model ML already owns and loves ….. they were built to the exact GO spec. Absorbing these into GO’s fleet will be very easy. If the strategy is a stopgap that is intended to last only until electrification makes some of the newer diesels redundant, it is perfectly reasonable.
ML has the same cycles of spending and cost cutting as any other business. And we have certainly seen ML having its share of money pits and cost overruns on specific projects. There is a risk that some projects will be cut to the bones to keep the cost to the approved envelope.
Are they the same units that we sold and derailed at Pickering?
No doubt MX is heading down the "value-engineering" path. The reversal on the Scarborough junction improvements, constructing at grade crossings instead of following through with the grade separation projects on the Stouffville line, and the recent purchase of second hand, F59's from Metrolink is a clear sign that MX has been directed to deliver higher frequent trains at the lowest costs possible. Hence why I don't believe electrification will happen as soon as everyone hopes. Similar to level boarding, they'll probably future proof every station for eventual electrification, but not have any set dates for when they'll actually follow through with it. They probably got the quote to electrify a single line and didn't like what they saw. I'm sure MX and the Ontario government doesn't want to subject riders to anymore construction in order to electrify a line, and just want to get the Stouffville, and Barrie lines double tracking completed and operating.
If they continue down this path I could see the feds threatening to withdraw some of the billions given to expand GO.
The Feds will be fine with it. Their narrative only depends on being able to say they are contributing funding to .... whatever is built. And all they want is the narrative, not the effective transit system.
The point @reaperexpress made, and it's a real serious risk is.... a scenario where the value engineering exceeds prudent value-for-money design challenges (which is desirable) and becomes short-sighted engineering-in of constraints (that bite us later, when the politicians involved have all retired) just to save money. Or goes unnoticed.... if Durham Region fails to expand as well as it could, because the GO service is too slow or infrequent, will anyone actually notice until it's too late? The decision not to build the flyover at Scarborough, the scaling back of grade separation and triple tracking east of Guildwood, building two-track bridges without roughing in the width for a third track, the awkward track plan for the routing through Oshawa.... these all will have been "value engineered" but may be profoundly unwise.
And since all of this happens behind closed doors, and represents a level of thought and analysis that politicians and voters generally don't get....
Re building two-track bridges without roughing in the width for a third track,
Are there specific examples of this you could point to?
I'm curious which streets it's alleged will no longer be grade-separated?
I think a lot of the crossings on the Stouffville line south of Unionville.
Google maps shows they're just laying down a second track across the road instead of grade separating.
MX still hasn't begun grade separating Danforth.
I'm going by my dusty memory of the most recent versions of a grade sep on LSE east of Guildwood, which only provided two-track width. and which I don't have handy. I will go hunting for the detail when I'm back at my desk in a day or so.
In a general sense, ML certainly seems to have scaled this work way back in timeline and scope.
As far as I know Danforth Road will be separated. That only leaves Progress that's south of Sheppard.
There's certainly approved TPAPs to separate and close everything other than Danforth - which seems by far the most critical. https://www.metrolinx.com/en/projec...pansion/studies/stouffville-grade-separations
Maybe this work is just being slowed down and the focus is (as always) on getting Lakeshore more service and electrified? The grade separation and new station station at Finch is underway now, so work is progressing. That new station opening before electrification or express trains will just add to already long commutes though. Hopefully when we get the West Highland Creek bridge and related track work done we can at lest get all-day, everyday 30-minute service.
If the Scarborough Junction grade separation for the second Stouffville line track is not built will the Stouffville line use the two north tracks and the Lakeshore East line use the two south tracks in the corridor? If both lines are running 2-way 15-minute service will this configuration allow for a LSE express train? Will there still be capacity available for VIA?
Its sad but entirely predictable. One can only hope that the value engineering has been done with the goal of prioritizing 15min frequencies at the expense of other promises and not wholesale value engineering for the sake of the bottom line.
Globally, almost every large infrastructure project that was designed pre 2020-2022 covid/inflation era has had to have significant scope reduction. Why would Metrolinx of all organizations be immune?
Three tracks still allow for express trains + VIA. I don't know why the 4-track configuration would be a concern.
Or what the big deal about the lack of a rail flyover is. If they can do it without ... why not. There's been zero indication that service would be impacted, outside of the fan groups.
I didn't know if the 15-minute service on the Stouffville line "consumed" too much of the 3rd and 4th tracks for the LSE to run an express on top of 15-minute service plus VIA.
