So apparently no more 6 car consists are being used?
Wasn't MX goal with GO from now on to run shorter trains that are more frequent?
As much as I liked the benefits of the 6 car consists, acceleration/deceleration/fuel savings, at Agincourt I could see a huge problem with them. Time and time again I saw people miss a train because they had no idea it would stop at the north end of the platform, far away from the station or southern end of the platform (for NB trains). The door operator wouldn't see them because they would be blocked by people getting off the train. It was a nearly daily occurrence. It was a great way to ruin a first experience using GO Transit.
Canada needs to be more European in regards to transit. ”World-leading North American transit” hasn’t existed since the 1950s. GO Transit will inevitably become more European with DB designing OnCorr.
I’m trying to not be petty, but due to your obsession with horns, I hope GO’s new trains sound like something out of the Netherlands.
Honestly this is North America.... We don't need any European nonsense, if GO ever gets these ugly trains I will probably just move to the U.S because they would have North American trains with lovely horns. "no offense to Europe" but if it ever happens "I hope not" the horns will probably be K5CA-LS's because it's mandated by transport canada for passenger trains.
This is indeed a problem, but can easily avoided without needing to run unnecessarily long trains.
Most importantly, the station needs to announce the size of the train before it arrives, so people can arrange themselves accordingly. Like you said, with a 6-car train, the cab car is 150 metres from the end of the platform, so it could take up to 2 minutes to walk to the nearest door if someone's waiting at the wrong end of the platform. Which is longer than the trains typically stop. Here in the Netherlands, the length of the next train is displayed on the screens, as you can see below. Dutch platforms are also 12 cars long like ours, yet it's no problem that this particular train is only 4 cars long. As in Ontario, you can see the stopping markers along the platform, so you just need to make sure you are between the <4> signs in either direction (you can see the blue <4> sign in the background).
Additionally, the accessibility car doesn't really need to always be the 5th car back from the locomotive. With a 6-car train, it could easily be the 3rd car back from the locomotive, allowing those trains to stop near the middle of the platform rather than all the way down at one end. It makes no difference to someone using the accessibility coach where in the train it is. Wherever it is, it will stop at the mini-platform at the station where you board, and also at the station where you alight. The only change required would be to install a second set of stopping markers for 6-car trains in the direction where the locomotive is leading. There are already separate stopping markers for 6-car trains while the cab car is leading.
If you were around during the ONR's TEE era, your head would likely have exploded. Trains, automobiles, aircraft from all over the world. Oh my.
Do us a favour and just move now.
just block, ignored him and hope the mods put him on sick leave. As long someone respond to his posting, he will post more of S^^
They were supposed to start announcing and displaying the train lengths about the middle of last year, when train lengths were far more variable than they are today. And it was specifically for the reasons that people have been listing here.
I haven't been on GO that much over the past several months, but I certainly didn't notice it on my last several trips.
If it was supposed to be implement some time last year, then it must be right on time cause I haven't noticed or heard any of this being implement at all.
It never happened. I thought about announcements/displays as reaperexpress suggested, but I guessed that might require a version of electronic train info communication that the network might not have right now. Can you provide any info on whether or not it is feasible to do that with the current network?
As I mentioned in my reply to smallspy, I doubted our networks ability to do this right now. I figured putting signs at parts of the platform that say something like "Off-peak trains may be shorter and not reach this end of the platform - please walk towards the accessibility area".
I definitely agree that for 6 car consists it makes absolutely no sense to have the 5th car be the accessibility one. That's an easy fix. I can guess why they don't do that already, simpler and less error prone, but it can't be that big of a deal to change that.
Also I understand that eventually this will be moot when we get level boarding.
Speaking of level boarding, why don't we have that to begin with? Is there some design consideration that precludes level boarding currently?
There is a clearance problem with the current car steps. It's solvable, but.... there's an old Larson comic showing a heap of cattle that is captioned something like "A stampede is something you have to organize, you don't just let it happen".
Level boarding is one more ball than ML ought to juggle while it is getting RER off the ground. It requires an extensive attention to detail, each and every station needs a survey and a modification plan. There are lots of devils in those details.
When I ride GO, I sometimes watch for signs as to whether level boarding has been roughed into each station. It's getting to a tipping point where more often than not, I can spot how a station has been prepped for eventual transition to a different platform spec. With so many stations being upgraded or replaced, the amount of this roughing-in is impressive.
So while I'm impatient with ML on other things, on this one I would counsel patience. It's coming - when the time is right. In the meanwhile, time and attention is better spent getting more track laid and getting to service on closer headways.
It could certainly be done very easily on a station-by-station basis today using the tools that already exist - the only change would be that the dispatching sheets would have to be shared with the Station Ops staff (or at least, some form thereof). They could then disseminate that data locally in a manual manner.
In terms of some sort of automated system to be displayed, I can't even see that being a particularly difficult thing. There is already a ton of information being sent to and from each station - this would be a pretty small addition to it. And at least to start, it would be unnecessary for the train itself to communicate that data.
The weekend Niagara train runs in service for 9 hours per day, similar to other trains in the network. It's a single trainset which does two daily round trips with a one-way travel time just over two hours.
And besides, a train with 2 F59s has more power than an MP40 (6400 hp vs 4000 hp) and more traction (8 powered axles vs 4). So it will definitely accelerate faster. The only downside is that there's a lower top speed (134 km/h vs 150 km/h). So you'd think that they'd put the F59 sets on a run which doesn't reach 134 km/h anyway, which is nearly every other run in the network.
The top speed on the Oakville Sub is 90 mph but on the Grimsby it's only 60 meaning that you can use a mp40 all you want on the Grimsby but the timetable speed is the limiting factor...
On most Kitchener line train rides I've been on we barely hit 75 between stations..
