beatle04
New Member
Do they use both locos as motive power? It would probably be moot but at the very least less time would be wasted accelerating on what is already a slow track.
From what I understand, only one is used.
Question 1: How do you get an immobile lead unit out of the way so that the rest of your train can depart?Could they have uncoupled the lead unit and have the train depart with one locomotive? Then haul the broken locomotive back to Willowbrook?
That would be the same as with VIA's Churchill service and having once witnessed one single F40 haul an entire Ocean summer consist from Campbellton to Montreal (after setting off an uncooperative loco), I can appreciate how overpowered a five-to-seven-car consist would be with two F40s on-line...From what I understand, only one is used.
It was the cab car that was having issues not the locomotivesCould they have uncoupled the lead unit and have the train depart with one locomotive? Then haul the broken locomotive back to Willowbrook?
Ohh i must have gotten confused, wasn't the issue caused by a cable problem (in really simple terms)?In theory, yes. But the crew tried a number of different things and none of it was sucessful.
I also don't know if GO allows the crews to handle the MU and HEP connections. They may require a carman to do that, which is a mechanic position rather than a running trade.
No, it wasn't. As I wrote earlier, it was the leading locomotive.
Did the issue occur while still in the yard or while loading passengers at Union Station? I imagine that you can't block a platform track at Union Station forever - especially during PM peak...In theory, yes. But the crew tried a number of different things and none of it was sucessful.
At this point, I have no additional information beyond what I've already given - i.e. the problem originated within the leading F59.Ohh i must have gotten confused, wasn't the issue caused by a cable problem (in really simple terms)?
The train had arrived at Union and was ready to start loading passengers. And yes, it did end up tying up a platform track for several hours.Did the issue occur while still in the yard or while loading passengers at Union Station? I imagine that you can't block a platform track at Union Station forever - especially during PM peak...
Every 15 minutes during the peak?This is a political promise, and as such could go in the relevant political discussion thread; but as the subject of the promise is a hot topic in this thread, I will drop it here too:
From Stephen Del Duca:
Oh man, so many ribbons to be cut! I'm surprised Del Duca hasn't combusted in delight.
