I'm curious if they can design a diversion to MCC while maintaining Cooksville GO.
I don't see that building a spur to MCC would impact Cooksville (or any of the stations further east). I can't see re-routing the entire line as an option. The only thing I've ever seen GO publish on the subject, did have the service to MCC passing through Cooksville - but how they'd achieve that I don't know, unless the entire thing was in a tunnel with a portal east of Cooksville. Though it's not even on the more recent long list of projects.
If you were to get GO to MCC (be it a spur, or continuing along the 403 west to the existing line), I'd think you'd follow the alignment of the TTC's 2001 proposed Line 2 extension from Kipling to MCC, diverging grom the existing GO track half-way between Cawthra and Hurontario, with a new station near Central Parkway.
look we already have a plan. Just take out the Eglinton drill and move it down here when done and we’re all good.
The GO tunnel from the Milton line to MCC (as a spur) was part of one of the province's Transportation Plans in the post-25 year period (about 20 years ago :) )
Interested in reading about this, do you know where this would be still available to read?
I took the GO bus to the airport for the first time (from Square One). The Mississauga Transitway is pretty barren of passengers from the looks of it. But the GO bus itself was well used. TBH I don't get the difference between routes 40 and 94, and somehow even I found it confusing which direction the buses were going. Clearly someone else did too because like 3 people had to deboard after realizing they had boarded a bus going the wrong direction.
The central section of the Ontario line downtown as subway may have made sense, but don't forget the plans for it are epic, from Burlington to Oshawa - and all that makes more sense overground.
But why? The distance from Burlington to Oshawa is nearly 100 km as the crow flies. That's what GO is for. That's not a distance you ride on local transit.
It doesn't really connect to anything useful.
They should extend the transitway westward to Trafalgar/407 in Oakville; and north alongside the 410 so buses can merge into the 407 while avoiding the 403/410.
Well I wouldn't say the Airport isn't useful...but aside from that, I think it's a major issue that it doesn't connect to the subway directly.
Its meant to be a modern interpretation of the Northern branch of GO-ALRT. Sure you could use it to go from Burlington to Oshawa, but the main goal is be a circumferential line that allows you to make regional trips that aren't downtown oriented (not requiring you to go through Union).
The same way that in London, you wouldn't use the Overground (future light blue Mildmay line) to get from Clapham Junction to Stratford. If you did, it would take 70 minutes non-stop, but 36 minutes if you take the South Western train from Woking and change at Waterloo for the Jubilee. And yet the Underground is well used.
Ultimately in Toronto, I doubt many will take the Ontario line from East Harbour to Exhibition, when they can take GO (assuming much higher frequency, without the near 10-minute hold at Union).
