KevinT
Active Member
Forced government rearranging of private ownership (not all farms are corporations)? Doesn't sound like a country I would want to live in.
I never said they should be forced.
I am thinking though that if anybody actually wants to move on HSR, they'll have to start talking to TC. It'll probably be a joint effort to define regs.
I quite agree, but I trust that farmers are quite capable of sorting things out on their own. Farmer A says to Farmer B, look, you now have x acres on my side of the tracks, and I have y acres on your side of the tracks. What can we do about that? Maybe the Province pays for third party assessments or soil tests or expert advice or whatever to help ground these discussions towards a mutually workable solution. Some people will refuse to play, others will look for the opportunity. Maybe it solves enough problems to be constructive and mitigate enough of the pain. The key is for the province to look at how it can help, not get in the way or force solutions on people.
My gut says more often or not, the rail line would have to duck under grade so the farm equipment alignment has an unconstrained clearance. Lots of excavation. Water table and drainage issues galore.
Doable, but don’t underestimate the cost. I suspect the Collenette study assumed plain old inexpensive grade crossings. VIA’s HFR seemed to do this also. Contrast this with TGV, where there is a huge investment in barriers in any place where there is even a remote possibility of a vehicle (or a cow) reaching the tracks. SNCF simply does not experience the North American events you see on Youtube where a vehicle has somehow gotten onto the ROW somewhere. One of my concerns with the Collenette study is that they may have lowballed the grade separation cost to an extent that could completely invalidate the construction cost estimates.
Which is why I support doing the EA - just to see how well this is being studied.
Class 7 rail doesn't exist yet in Canada. Class 6 limitation in Canada is 110mph, (177 kph), as it is in the US. The US allows Acela at grade crossings on Class 7 track @ 125 mph (200 kph+). It presents a conundrum in terms of how Canada is to move on this, something TC must face up to. HFR is touted to do 200 kph. And that includes remote level crossings. Doubtless, full warnings would be needed, and barriers.I’m not able to find anything in that third document about railway track with a design speed above 95-100 mph. Am I missing something?
While the design of railway crossings below that top speed are very thoroughly laid out, I’m still not confident that TC has reached a level of comfort and specificity about higher train speeds that would let anyone implement a level crossing above that speed. Hence my belief that their response to an actual proposal will be “We will get back to you”.
Well I guess we can kiss this project goodbye, at least for the next 4 years anyways.
For "HSR" to London and beyond? Agreed.Can probably shut this thread for another four years or so, now, or at least the discussion about the cross-country route.
It could work so long as one farmer's X equals the other farmer's Y; otherwise, somebody is taking on debt. Around here, cash crop farmers rely heavily on working leased land. It's a bit of a vicious cycle: you need big equipment to maximize cost efficiency, but big equipment means you've got to keep those big wheels working. Some up here work well over 1000 acres, most of which they lease because nobody could reasonably assemble that amount of land. If S/W Ontario is anything similar, equipment mobility and access will loom large.
Some remain focused on HSR with very few stops. I am hard pressed to see a rural municipal tax base, especially a lower-tier one, coughing up share funding for things like grade separations or compensation packages when they will see no economic benefit.
Will London just get GO service now?
What London should want/push for is better Via Service....the type of service they offer and the type of trains they use are far more suitable for trips of that length. Not sure how people in KW and Barrie put up with 2 hours on a GO train....but anything longer than that seems just unfathomable.Will London just get GO service now?
I'm looking at the election results map, and I see the most likely places for rail stops are all orange, and all the areas that they will go through without stopping are blue.
I'd say London will get nothing. GO Bus, maybe.
The tracks are in horrible condition in some spots on those lines which is why it takes so long. I think London will get something, which is like ToareaFan said more via service. I do think GO trains might be cheaper, if done at high frequecy rail.The PC's under Brown's platform promised to continue HSR studies. I believe local candidates during the election continued that stance after Ford became leader. It's not explicitly dead.
This whole project has never been anything more than political posturing anyway.
I drive the Oxford back roads south of the 401 much more often than to the north, but I am conscious of just how many Mennonite communities there are out there. That’s a whole ‘nother set of farming economics and sensitivities to factor in.
