Flew around it today. I had to be up over 300 meters to comfortably move around it. Not sure of the exact height to clear the antennas, but I was definitely over 300 meters just for the roof.
I measured it on Google earth pro it was like 292m if I recall while other buildings were accurate to what they claim.
@hawc the drone uses a barometer for height which is not calibrated perfectly
I've just learned that upon completion, O&Y registered the building with Guinness as 'the tallest bank building in the world', for which I assume they would have had to supply some documentation. The record was set at 935 feet or 284.9m. It is unclear from what and to what Guinness measured / measures that record though.
That seems accurate to the roof, minus the mechanical penthouse. Google Earth measures that at around 286 metres - with lines up with Google Earth generally measuring a little bit above actual height.
I would say that it's pretty safe to say actual height is 291m to mechanical penthouse.
The City's shapefile has FCP at 287m so that's almost exactly Google's listing too.
