Asmegin
Active Member
Anywayyyys...
Regarding the utility room - don't let it get even near the freezing point. 10-12C is about as low as it should go (incase of flash freezing). When the guy came and turned it off (he did go to every unit last spring), he said they would be sending out a note for fall/winter. It's getting pretty cold at night so I'm guessing they forgot about it? It would also make sense for Skywater to go to every unit and turn them on. Some people may not really know about it/know how to turn it on, which could result in huge damage.
Hallway air - yeah, still frigid. They're probably turn the heat on soon - hopefully! Will heat up our units a lot too![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I found the model for the heater, and it says the built in thermostat is optional. Guessing they didn't add it to ours?
http://en.stelpro.com/contenu/ca/pdf/fiches/RWF.pdf
Maybe we can get something like this if so:
http://www.amazon.ca/Lux-Heating-Co...=1382476384&sr=1-1&keywords=thermostat+outlet
