dunkalunk
Where would you put the portals? I dont see where there would be space to do so.
I would put the portals in the street. Right before Clarence Square, I would have the 3 left lanes descend into the tunnel, with the right line being either the tunnel or straight through to connect to Spadina. The boulevard west of Spadina would start off with 1 lane coming off Spadina, and then the 3 lanes would come up in the roadway and join with it, creating a 3 or 4 lane half of the boulevard.
The tunnel would require some pretty sharp turns, but traffic would be flowing at street speed, not highway speed at that point anyway, so sharper turns aren't as bad when you're doing 50 km/h (although most times it will probably be around 20 km/h) anyway.
I like it, although I think the tunnel would only need to be 2 lanes wide as in my plan, the viaduct would be be a 4 lane roadway and the third lane would only be needed to accommodate turning movements. It may also make sense to tunnel Front under the intersection as well in order to improve traffic movement at that intersection.
Also, upon further investigation it may still be possible to bring Wellington to Front at-grade. According to this post, the footprint of the Fly Condos still leave room for a 2-3 lane roadway, unless there is another project in this area I'm unaware of. In any case, it should make cut and cover construction much easier.
We do not need any more large 1 way streets in downtown Toronto.
We also shouldn't drastically alter our city to accommodate automobile traffic at all. Connecting the Gardiner to Front is all well and good, so long as we bring it down and turn it into a boulevard intersecting all major streets. The highway itself is not beyond capacity, but we ought to spread out the volume between different access points to avoid congestion.
People will still move moderately fast through it. Only those who want to travel across all of Toronto will suffer, and it's silly to have people do that through downtown anyway.
The majority of solutions proposed in this thread fully ignore the potential of streets like Front and Wellington to turn into some of our finest streets. As population increases in the core we should be looking to widen sidewalks and add bikelanes, and not to try and accommodate suburban drivers.
This argument can't really be made against realigning Front and Wellington as one-way roads as Wellington is already one-way and the bulk of the development on those streets is highrise office and condo. They are not small-box commercial streets like King or Queen. I wouldn't propose the conversion of two-way roads to one-way anywhere else in Toronto; I would call Wellington and Front the exception to this rule.
And if the streets were converted to one-way and narrowed to 3-4 lanes from what is currently 5 there would be room to add on-street parking, widened sidewalks, and sheltered bike lanes, all of which would serve to calm traffic.
And as a reminder, people will only travel as fast as road geometry and light timing will allow them to travel. There are ways in which one-way roads can be designed (not like Richmond/Adelaide) that will ensure that.
I couldn't agree more that we shouldn't do anything to accommodate more car traffic. But what about taking the existing plan here to connect with Front and demolishing the Gardiner between the proposed connection and the Richmond/Adelaide ramps at the DVP? Without increasing car traffic capacity on Lakeshore Blvd, Front, Wellington, Richmond or Adelaide. Congestion could be managed by a combination of meaningful road tolls on the Gardiner/DVP, significantly higher taxes on core parking spaces, and increased GO train frequency. Suburbanites would scream but I'm not sure Toronto needs to continue to blight its core so people can whisk from Oakville to Oshawa via downtown Toronto.
