Rainforest
No transit construction will start on Sheppard in the next 4 years, or in the next 8 years. There are too many other priorities, no matter which party wins tomorrow.
After that, who knows.
How ingenious.I agree. Line 4 should end at McCowan and Sheppard with Line 2.
Hopefully built like this
It's kind of dumb having all those bus routes funnel on McCowan bridge over the 401. Its poor planning aka half assing.
That's why a McCowan stop with a bus terminal to attract bus routes north of the 401 makes more sense and helps circulation in the area as a whole.
That makes more areas desirable to live in instead of forcing everyone in overcrowded areas that won't have the appropriate transit infrastructure to support it anytime soon.
I disagree in this case. I think this sheppard extension needs all the ridership it can get. SCC will provide that.A new bus terminal is a good thing, there should be multiple bus terminals on the extension(s) to minimize bus ride times. The giant ~10 minute walk from the far end of the STC bus terminal on the SSE should be optimized by splitting the bus terminal between Sheppard and Lawrence.
Doug will push it through.No transit construction will start on Sheppard in the next 4 years, or in the next 8 years. There are too many other priorities, no matter which party wins tomorrow.
This is what I think will happen. Yonge North, DRL, and SSE are close enough to construction to have shovels in the ground at the end of this term. Sheppard needs to start from scratch, it's going to take time to start. At the very least until next term.No it will likely be a design start and will be used for another couple elections to keep support of Scarborough residents. They don't want to rush this one to quick? Certainly not after they are closing in on delivering a subway with actual stops in Scarborough with the SSE
SSE with stops, DRL short and possibly Yonge have the green light to move forward towards construction. Surface LRT plans will all be put on hold or thrown back to the City to fund for the most part on their own.
I think the PC had made it a priority to cut down drastically the time it takes to deliver a subway line. 10 years is utterly unacceptableI disagree in this case. I think this sheppard extension needs all the ridership it can get. SCC will provide that.
All the LRTs are dead, for sure. I think you will see Eglinton west possibly built as an elevated line. Eglinton East will either see the city fund it or see it die. Waterfront East will probably scrape together funding from the Feds and the City.
That's also at the PC advantage if they can build faster.Yes, I am still amazed at how Vancouver built the entire Canada Line from stratch in under 4 years yet it took for TYSSE and is taking the Crosstown seemingly forever to be completed.
Toronto's planning paralysis definitely needs to end.
After nearly over a decade since the planning, all the Liberals have to show for it is Vaughan subway.
People are more favorable to things that are completed and operational.
The PC building faster means they could have a steady stream of completed projects within their terms. They need to change that negative perception people have of their transit track record faster.
Building subways faster is one way to do it. One of the reasons to upload the subways was to make the financing easier as well.
Without disregarding past PC mistakes, the fear mongering is going a bit far in my opinion. I think we should see what they will end up doing if they grab a majority.
The pace of transit implementation in Toronto is largely due to the Fords, who did nothing but slow things down.
Ford is promising everything to everyone as though he's running for class president in an 80s sitcom.
It would be great if the PC party could speed everything up, but based on his track record there's no reason to believe him.
It's not fear-mongering, it's using common sense.
Fool me once...
