M II A II R II K
And would provide Durham with an uptown option unlike the GO.
How/where would the Sheppard line go above ground, though, and what routes would it follow to the west/east?
Even earlier than that, one of the GO-ALRT lines would've used the Finch Hydro Corridor as well as the 401 corridor and would've provided headways as low as 2 minutes using fully automated trains.Random thing I found doing some digging for a slightly related project of mine. Apparently the idea of rapid trainsit running alongside the 401 to Durham isn't all that new. According to this map, during the Network 2011 days there was a plan (or idea at least) of a GO line (or regional equivalent) running between Durham and STC via the 401 and Kingston Road corridors.View attachment 270651
Just keep in mind that the 401 collector/express system doesn't extend past Neilson at the time this map is publishedRandom thing I found doing some digging for a slightly related project of mine. Apparently the idea of rapid trainsit running alongside the 401 to Durham isn't all that new. According to this map, during the Network 2011 days there was a plan (or idea at least) of a GO line (or regional equivalent) running between Durham and STC via the 401 and Kingston Road corridors.View attachment 270651
I think the options for above ground are mostly in the 401 corridor, and using that corridor makes sense for the outer sections only. We don't want to lose the density opportunities in the middle.
In the west, I'd suggest going mostly underground until Allen Rd; the West Don crossing may be on a bridge though because the valley is very deep. After connecting to Line 1 Sheppard West station, the line can turn south and continue at the surface level from Sheppard to Wilson.
Within Toronto there is a lot of opportunity to densify corridors like Sheppard or Wilson. Outside of Toronto it would likely be more oriented to commuters, and at some point one would expect density to find a place around those outer stations. Considering the branches to the west, if there is a branch to DT Brampton, we would have to choose a route that does not compete with the Kitchener RER (which I am not sure of a route). A Mississauga branch could follow highway corridors from YYZ all the way to Square One and potentially beyond. In the east, if we intend to extend the line beyond Pickering, it would compete with the Lakeshore RER so it may be worthwhile to use the hydro corridor or something north. Would also set it up to have a branch to the "Pickering Airport" when it gets built in the year 2076![]()
I think there's more merit to continuing into Mississauga to connect with Milton line. Brampton would already be connected with Kitchener Line. Just funnel routes into Brampton, Bramalea and Malton GO and provide frequent service to connect at Etobicoke North, since Kitchener line will be getting frequent service. It is pretty redundant run a different technology to Brampton on a different ROW.
Maybe GO Expansion gets done with the same technology and the branch just uses the Kitchener line?
If you're extending the Eglinton LRT to Mississauga, might as well extend this line if both lines would be extending from Renforth/Pearson.
Side question, is UP getting replaced by the Kitchener RER? I would love to see it stay, and have the corridor see 7.5 minute or less headways between downtown and YYZ, oh boi, that would basically be relief line west resurrected right there![]()
