MacLac
Well now that mid rose portion looks waaaayyy different….
LinkedIn Login, Sign in | LinkedIn
Login to LinkedIn to keep in touch with people you know, share ideas, and build your career.www.linkedin.com
Which cladding... the podium?Excited for them to finally start peeling off the covers on the cladding to reveal more of it.
Was reading more about what they used, cool stuff: https://alucoil.com/wp-content/uploads/2021/06/CATALOGO_LARSON_2021_INGLES_v1.0.pdf
TowerWhich cladding... the podium?
If you look closely there is a vapour barrier (Tyvek style) applied to the whole building going to the top floor, then backing panels with aluminum studs/battens being installed, and then the Larson panels mounted on-top (that kind of looks like a Tyvek wrap). They’ll probably end up tearing off the protective material more/less all at once.^
...unless that "Larson" is the panels which I"ve interpreted as another version of Tyvek as there is no way they can install panels that quickly.
