If Douggie and his friends can figure out how to make his friends rich developing on the protected Greenbelt they can wave a magic wand and make the flood plan dissolved. If there is money to make it can be done, if there is a will there is a way..Nope - from TRCA Flood Plain Map:
Guess we figured what the machinations are here.
Not surprised at the incompetent CM of this debacle, but still extremely disappointed.
Eglinton is no where close to being "almost filled in".Do we know what the hold up is with this line opening? Eglinton station is almost filled in. Can't they do testing on the line without the station being "ready"?
A friend of mine who is an operator on the subway sent me a photo a couple of days ago.Good Clip, I've extracted a couple of stills:
Observations. Flooring mostly (but not entirely) complete.
I assume the column in the second shot will have some sort of cladding/build-out.
Ceilings unfinished.
No permanent lighting yet, though wiring for same seems to be in place.
Well what ever the reason is, its a result in poor coordination amongst the trades/disciplines. They've had more than enough opportunities measure 5 times to cut once yet they still manage to bungle it up. Then again ML has some of the most complicated communications scheme out there. Even a simple question must be RFIed formally, whereas anywhere else you can just pick up the phone and get a 5min answer tight there..Waterloo's ION had a few station platforms broken up and re-poured ahead of opening as well. If I recall correctly, it's because the platform edges weren't the correct distance from the tracks. Different cause, similar result.
How will this affect the current southern end of the platform? Will the train just stop very far away from the south end? The elevator’s proximity to the southern wall prohibits putting up another wall.A friend of mine who is an operator on the subway sent me a photo a couple of days ago.
I wonder if the video was taken earlier, as his photo shows most of the columns clad, the flooring done, and much of the permanent lighting in place although not yet turned on.
The current rumour is that the platform extension will open on May 8th.
