T3G
Call me crazy, but wouldn't it have made sense to build trackage that could withstand CLRV operation along it?Built 2006-2010 making it due for track replacement now the tanks no long run on it.
you guys aren't reading the facts on it. doesn't have to do with tracksCall me crazy, but wouldn't it have made sense to build trackage that could withstand CLRV operation along it?
TTC has been rebuilding their system with a new style where the tracks are supposed to last 20-25 years, the subbase including the ties 50 years and the base 75-100 years. Curbs will see replacement sooner since there take more pounding than straight track. Switches have no timeframe other than when they need to be replace. Most to all of us. if not all us will be around to see if it really will happen for the first 2 timeframe and none for the full cycle .Call me crazy, but wouldn't it have made sense to build trackage that could withstand CLRV operation along it?
Concrete and track repairs will occur at various locations along the route including at Bathurst, Vaughan and in Oakwood Loop. Track lubricators will be added at Oakwood and Earlscourt Loops to reduce wheel squeal.you guys aren't reading the facts on it. doesn't have to do with tracks
how are the at-grade sections different? can regular maintenance also long-term shut down the line?Concrete and track repairs will occur at various locations along the route including at Bathurst, Vaughan and in Oakwood Loop. Track lubricators will be added at Oakwood and Earlscourt Loops to reduce wheel squeal.
Crosstown ROW and TTC ROW are 2 different animals with Crosstown seeing less impact on it.
The only major track replacement project is at St. Clair West, where the entirety of the loop will be replaced.Concrete and track repairs will occur at various locations along the route including at Bathurst, Vaughan and in Oakwood Loop. Track lubricators will be added at Oakwood and Earlscourt Loops to reduce wheel squeal.
Meaning what, exactly?Crosstown ROW and TTC ROW are 2 different animals with Crosstown seeing less impact on it.
The different between the 2 ROW is the fact that Crosstown doesn't have concrete around the rail nor sees any traffic on it other than at intersection. Crosstown base from the west portal to Kennedy Rd has a huge duct bank at the base for Hydro, cables, and other things compared to TTC small duct bank for TTC only...how are the at-grade sections different? can regular maintenance also long-term shut down the line?
The addition or subtraction of concrete around the rail has no bearing on the longevity of the rail.The different between the 2 ROW is the fact that Crosstown doesn't have concrete around the rail nor sees any traffic on it other than at intersection. Crosstown base from the west portal to Kennedy Rd has a huge duct bank at the base for Hydro, cables, and other things compared to TTC small duct bank for TTC only...
Considering that we have not yet seen a track replacement on the Crosstown, this is a very premature assumption.It takes less time to replace tracks on Crosstown than TTC ROW including switches since no concrete has to be removed or add other than at intersections...
Wasn't talking about timeline for rail life cycle in concrete, but the time it takes to remove it and pour new concreate compare to removing the rail clip. Both types of ROW use the clip system and it should be the same length of time to remove and reinstall rail. TTC has to remove and reinstall concrete at an extra cost to do it as well a longer time frame to do the work.The addition or subtraction of concrete around the rail has no bearing on the longevity of the rail.
There are two duct banks along Eglinton. One for Hydro and others, and one for the transit system's requirements. Just like on St. Clair.
Astute distinction!More important, service can still operate on a single track with longer headway for service on Crosstown, compare to detours for TTC streetcars while rail are replace.
There are 2 for grade level with one at Sloane Station area and the other at Birchmount Station Area that are far apart. Can't speak to the tunnel, but expect the same as the surface.Astute distinction!
From all your visits do you happen to know how frequently track crossovers are being/have been installed on these new lines?
Again, they replace carstops in a weekend, and that's including pouring a new top layer of concrete. It's not a long process.Wasn't talking about timeline for rail life cycle in concrete, but the time it takes to remove it and pour new concreate compare to removing the rail clip. Both types of ROW use the clip system and it should be the same length of time to remove and reinstall rail. TTC has to remove and reinstall concrete at an extra cost to do it as well a longer time frame to do the work.
Well, yeah.Until we see rail replace on Crosstown, assuming it will be fast as TTC.
Not necessarily. It's going to be very location dependent.More important, service can still operate on a single track with longer headway for service on Crosstown, compare to detours for TTC streetcars while rail are replace.
As I wrote above, that may not necessarily be the case. We will see.Finch and Mississauga ROW can operate on a single track while rails are replace with Finch taking a lot longer based on how they are installed that doesn't match TTC, Eglinton or Mississauga system. That said, intersections will be a different story.
Well all of the crossovers have been installed and used, so they're not going to be putting in any more.Astute distinction!
If one postponed things like power washing because of a rain shower I can assure you it would never be done -As I passed Bayview station today, they were power washing the concrete pavers in the mini plaza by the entrance to the NW corner. I didn't bother looking at the SE entrance, but it needed a lot more work done as of a few weeks ago as it's the main entrance, with a bigger footprint etc.
I'm not sure how useful it was to powerwash things with the storm we have going on right now, but I figure there must've been a point to it.
