 9.1K     0
 5.3K     0
It can't just be left or it will be back to dirt within 20 years. Tunnel. even one without any trains running through it would require frequent inspection and repair.
I believe that when people are refering to tunnel, they are assuming it is a pre-cast concrete lined tunnel. The TBM also does the lining as it goes along. If I am not mistaken, I think that the lined tunnel is built and afterwards (usually shortly afterwards, but not necessarily), the station is excavated by cut-and-cover and the small 150m segment of tunnel is "destroyed" in the process of building the station.
I thought the cost of this lined tunnel was in the $100M/km range.
Sure, just like Yonge line which has undergone a rebuild process during the last 7 years due to the tunnel beginning to cave-in (it was no longer the original shape) from soil movement around it.
A pre-case concrete lined tunnel does not last forever without maintenance.
An unused and mothballed line costs nearly the same to maintain as one with passengers (see TTC documents on cost savings from mothballing Sheppard when it was threatened).
You can assume that over 50 years you would spend an ~$1M/km/year in maintenance on a tunnel without stations or active trains to keep it in a state where you could build stations and use it in the future.
From the Star.
The earth dug out for the Eglinton light rail transit line could be turned into islands in Lake Ontario.
At least that’s one proposal as the city considers ways to improve the water quality off some of Toronto’s Lake Ontario beaches.
The string of islands would go in at the mouth of the Humber River and extend about one kilometre from shore. The plan would take clean fill from construction jobs to build a solid earth barrier underwater that would deflect polluted Humber River water out into the lake and away from Sunnyside Beach.
If this goes ahead, we must remember to charge residents of Clarington an admission fee if they want to visit our new offshore archipelago. It'll be all their doing. :)
With all the earth fill-in, Lake Ontario is getting smaller and smaller. It used to reach Front St in the 1700's
Lake Ontario is 18,960 square kilometres in area -- I doubt a bit of fill-in will significantly change its "size".
That's interesting, I had no idea. I often wondered why Front Street wasn't at the front of anything, I guess it was.
That is why Fort York is where it is today. Do you think Toronto could be protected to day where the fort is now?
Most people have no idea how much of the waterfront got push out from the original location.
The RR tracks going to Humber River ran alone the shore line. The Portland was only a small marsh and there was a shipping channel there at one tine.
Ford filibustered the debate to today (he is even seen running away from council to the elevators). He still thinks that LRTs are streetcars, despite all the evidence on the contrary.
You're right, the LRT network wouldn't be a streetcar network. It'd be two streetcars articulated running in the middle of the street, no different from Spadina or St Clair W, with stoplight priority running at the same average speeds. *Totally* different technology.
LOL
Let's not kid ourselves, TC was openly a plan to do transit on the cheap. Cheaply made transit isn't transit built to last. But, if Toronto can't come together, unite, and agree to build something the entire city will fall behind as the needless arguments continue.
As a subway supporter, I was relatively happy seeing the "compromise" to place Eglinton underground, make it above ground in Scarborough and link it in with the SRT and proceed onto a DRL at a later date. But the needless arguments seem to be starting all over again.
Rob Ford is a moron no matter how you put it, but the thing is that people who are pro-subway aren't pro-Rob Ford. Many people just want *something* coherent to be built, and built within our lifetimes.
LOL
1. $8bn is not pocket change. The question is what do you do with that $8bn, right? I'd rather do 'something coherent' (all-LRT) that connects the most parts of Toronto.
2. Unless and until people who are 'pro-subway but not pro-Rob Ford' come up with a way to PAY for their subway, they're pro-Ford, because they're pro-Ford's plan.
And a Q for the crowd: This is the x millionth time that someone has said that we'll still have bunching due to 8 cross streets on a very small percentage of this route. Is there no provision, anywhere along this line, for a train to be put into or taken out of service, except at each end? Is there no way to tell a driver, once they're in the tunnel, to SLOW DOWN and give some space? I find that VERY hard to believe.
The Eglinton tunnel is expected to be using the exact same signaling that is being installed on the Yonge line. ATO, moving block, central transit control (exact same control center staff as the rest of the subway system), etc.
Any and all of the features available to control our subway trains are going to be available to control the LRT in tunnel as well.
No, we don't support Rob Ford. The biggest problem with $8 billion in funding is that the Miller/Giambrone setup could have made it a priority to build a DRL and forget LRT altogether. $8 billion would have went a long way toward DRL if the previous leadership would have made it a priority, unfortunately nothing is happening now because of all the in-fighting.
If DRL would have made a priority back when we had a reasonable mayor, then you wouldn't have seen this surge of infighting among different people who all support transit. Leadership tends to create the discussion and the debate that ensues follows the trends set by the leaders who set us on that path. Miller and Giambrone decided to go on the LRT bandwagon and set the city onto a divisive path, and likely caused the Rob Ford administration because so many people opposed what was seen as waste. TC was seen as a wasteful project, unfortunately Rob Ford was able to latch onto that sentiment and get votes and we ended up with mayor idiot.
TC was divisive, costly, yet cheaply done transit. It tried to do too much for too many people with too little means. Toronto could have been digging tunnels for a DRL already if the $8 billion were to have been funneled into a less debatable, immediately recognizable need.
If Rob Ford were an honorable man, he would be nice to all sides understanding that we all support transit - the TC crowd included - and start using city lawyers to see if he can use the $8 billion in finance without paying penalties to start a meaningful project like the DRL. He'd also admit his private finance scheme is a pipe dream and admit a major failure on his part.
But then again, that would be if he were a true leader and not some pompous idiot.
Mind you we're fighting over what is essentially suburban transit services. Does Toronto really need to focus so heavily on improving far-suburban locations like Finch or Sheppard when the old city needs DRL now? Sheppard subway isn't a failure, for its short length it serves more than many other transit lines in North America. 5.5km is a very, very short distance, and in that distance it achieves 50,000 ridership. If you look at the Red Line in Chicago it is very, very long at 23 miles (37km) in length, yet it gets 248,000 riders. I used to live off the Red Line in Uptown for a few months while I was in Chicago, so I've got experience riding both lines. The Red Line is one of the "backbone" lines in Chicago, the stubway in Toronto achieves more ridership per kilometer. People in Toronto do use transit heavily, whereas other North American cities don't really utilize their systems.
So I happen to think the Sheppard stubway is an example of high transit usage based on real world examples, but what didn't it do? Sheppard isn't an urban corridor, it is still suburban with increasing condo presence. This is really what it should be, seeing that its a suburban location.
I think the TC supporters mistakenly believe that TC would convert suburban Toronto to some urban utopia where Finch and Sheppard would become Queen West, but that isn't what would happen. Of course there are others who think TC was true rapid transit, it isn't, so they think it'd be the speed comparable to subways with a fraction of the cost... Which is the biggest folly of TC.
But getting back to Toronto usage, lets compare the backbone of the Chicago system: CTA's Red Line to the Yonge-Spadina subway.
Red Line length - 37km, daily ridership 250,000
Yonge-Spadina length - 30km, daily ridership 715,000
We're talking about roughly 3x the usage. Even when you add on the Brown Line elevated track downtown for the second north-south feeder into downtown Chicago, it has length of 18km and only has 105,000 riders a day.
So lets put this into perspective...
CTA Red and Brown line combined - 55km length, 355,000 riders a day.
Yonge-Spadina - 30km, 715,000 riders/day
When you start looking at other cities, you soon learn Sheppard subway isn't under-utilized at all. AT ALL.
What this is centered around is a paradox... Suburban Toronto won't become Queen West, but it needs improved transit. I have no doubt in my mind that Eglinton Crosstown would likely serve more people than the backbone of the Chicago system in years to come. I could easily see it achieve 250k riders/day. But the paradox is that a DRL in Toronto is so much more badly needed.
