rbt
Also keep in mind that the 400m-500m-600m circles are a very simplistic way to visualize the area influenced by a station.
That area has a decent streetgrid. A circle is going to be pretty close to actuality.
The catchment area along Eglinton which is walking distance from, say, Oakwood, but not Dufferin or Eglinton West is 80-100 houses. It's not like by dropping Oakwood we'd be dropping coverage to Kowloon. These are 600m radiuses.
People here are vastly overstating the additional coverage stations like Oakwood provide.
Moreover, simple metrics like coverage are kind of meaningless since most riders reach rapid transit stations by connecting routes. Walk-ins simply don't account for much ridership, so improving walk-in coverage by covering a few extra houses makes hardly any contribution to ridership.
It's not "walking 400 metres".
It's walking an additional 400 metres once you've finally reached Eglinton. Or worse yet, running a parallel bus service (and having to pay for it).
Only a small percentage of the catchment area of any given station is on Eglinton.
Last I checked, it is difficult at best to walk through people's backyards in an attempt to make your walk more direct.
Those circles are nice, but also fairly pointless. A more accurate map would have an actual 600 metre path along every single walking path. You will see that the catchment area is quite a bit smaller than you think.
Yes, you're right.howl said:Therefore you can't say, just based on the circles, that Oakwood will definitely have fewer riders than, say, Bathurst, only that your gut feeling is it will generate fewer riders. When you look at the details you might be right or wrong.
Wow, a whole 550 metres. Boy oh boy. What can I say. I'd rather not.
Mt Pleasant & Yonge station's overlap is justified in my opinion due to the very high density of that block (it's all apartment buildings and condos, with more condos to come).
That's a whole different kettle of fish.
Mount Pleasant to Yonge is 600 meters, Mount Pleasant to Bayview is even further, and not only does the Mount Pleasant and Eglinton area have a high density of population, jobs, and high school students, but it also intersects with a north-south bus line.
This discussion is ridiculous. If you can't manage at least a 700m walk you should be on Wheel Trans.
Good points. I would actually prefer the Mt Pleasant bus to simply run up & down Mt Pleasant instead of having two routes that go into Eglinton station & St Clair station, and also go downtown to Jarvis like the premium express bus, and be more frequent. I think it would get higher ridership in that case.
Yup. I only recall getting on the Mt. Pleasant bus like 5 times in my whole life because it is always faster to walk from Eglinton to Davisville than it is waiting for a bus. It is that infrequent.
The Davisville bus is also pretty infrequent, despite the rather large number of people I see at the bus stations along that route. Never understood why, it is a short route. Surely you can get a bus driver to do a constant circle of the route. I've heard that the bus drivers on that route take a 30 minute break at Davisville Station after every run.
The buses in that part of Toronto remind me of service in a midwestern city in the US: non-grid, non-frequent services that seem to chase away ridership with their bad design.
For example, you can't use a bus north-south through the entirety of Leaside in Bayview without transferring from the infrequent 11 to the even less frequent 28A at Davisville. Then there's the infrequent 74 along Mount Pleasant, despite the fact that Mount Pleasant is quite a vibrant strip.
It seems that the job of most of those routes is just to funnel people to the [overcrowded] Yonge subway line. I wonder if having one frequent service north-south route along either Mount Pleasant or Bayview would help local travel patterns and relieve the Yonge line (albeit very minimally).
Like rbt said, with a fairly decent grid, the circle will closely approximate actual distances. That's why I used fairly conservative distances (600m, vs. the more standard 800m), to try to account for minor reductions.
What destinations/origins exactly do you see an Oakwood stations serving that nearby stations couldn't serve? Can you realistically see more than 100-200 houses that would be left out? Why are you assuming walk-in ridership is even very important to net ridership?
I didn't want to overemphasize radial coverage circles. Particularly for rapid transit, where "coverage" is more a function of connecting surface routes than any kind of local demand.
