glass exteriors last around 40-50 years. Buildings tend to need a recladding after that, as seen with many older glass buildings. (UN building, TD centre, FCP off the top of my head)
Those are examples of high quality bank and public buildings that were built to last and not hastily-constructed boom units built for quick flipping and specking. Banks can afford to reclad buldings, what happens when an entire condo has to vacate because their built-to-minimum-code investorbox needs its entire exterior window wall replaced? That's going to be one heck of a special assessment to be hit with!
Funny because that's not how it works at TD and FCP. Both are not owned by the banks, but rather leading companies like Oxford and cushman Wakefield. Those are the ones that pay of it.. As for glass replacement, the buildings were fully occupied during the recladding. I'm sure the replacement of condo glass would require someone to vacate their condo for no more than a day while a crew comes in, removes the old glass in their unit, and replaced it. Do this to 400 units, with say 4 crews, you can get the work done for te whole condo in about 6 months.
Anyone buying a house also has to consider that at some point they too will have to replace their windows, their roof, their furnace, etc. Every condo corp is required to perform an engineering study to predict the capital costs going forward of keeping the building in good shape, and a portion of monthly assessments go to the capital reserve fund to handle the major expenditures when they come up. As long as the condo board has been diligent, special assessments should not be necessary.
42
*sigh* Let me rephrase: The owners of bank buildings can afford to re-clad their properties. And FCP was more a failing marble replacement than a window job. Plummeting chunks of marble = not good for business.
While the patching or replacement of a single pane of condo glass would not require much effort, the re-skinning of an entire building would. Not only would it require that all residents move out for several weeks but it would cost each owner a mountain of cash (via special assessment) and seriously affect the resale value of each unit.
This is worth a look. The professor appears to have no 'skin in the game' as it were nor do dollar signs appear in his title (just Ph.D). It is a long read (maybe 500+ tweets, all weirdly strung-together-like) and there are no dramatic night renders or world-class skyline shots. Despite these shortcomings, he seems to have garnered some knowledge of buildings and stuff and things. Maybe he passed a 6 week RE course?
http://www.daniels.utoronto.ca/files/condo_conundrum.pdf
An excerpt:
"But first, let's begin by looking at the typical situation being forecast for glass condo towers, beginning at the point where a new condominium is handed over to the condominium board comprised of unit owners. At this point the Tarion condominium coverage has come into effect as follows: One Year, Two Year and Major Structural Defect warranties are in effect, where the aggregate maximum warranty coverage for new homes and condominium units is $300,000. The maximum coverage for condominium common elements is $50,000 times the number of units, to a maximum of $2.5 million. All minor deficiencies are covered under the One Year and Two Year warranties and between years 3 and 7, the Major Structural Defect warranty applies. The latter is rarely invoked since the reinforced concrete structures of condo towers are well engineered and constructed. Normally, by the end of the total warranty coverage period, isolated performance problems begin to occur within the window wall assemblies, mostly visible as water leakage. These are remediated on an as-required basis until such time as the problems become chronic and extensive.
At this time, the least expensive repair is to seal the exterior face of the window wall assemblies over the entire building.1 This expenditure is not usually forecast in the reserve fund study, and hence it requires a special assessment be levied against all the condominium unit owners, prorated on a floor area basis. This form of remediation only lasts for 10 to 15 years and then it must be either repeated or the entire window wall facade replaced. If the former option is elected, then the repair work becomes quite visible and these special assessments must be disclosed to prospective buyers. Not only does the building begin to look shabby, but it also has relatively higher maintenance fees than more durable condo towers. Alternatively, a much more expensive special assessment for replacing the entire building envelope can be levied and then a proper allocation for future maintenance and replacement be included within the reserve fund. What is important to appreciate is that either way, the market value of the condo tower is affected, and its marketability can also be compromised by concerns over appearances and/or durability and performance problems.
1 A significant proportion of the repair cost is associated with staging that allows technicians to go up and down the exterior of the building facade to work safely and efficiently. For this reason, performing numerous, intermittent spot repairs is often more costly than sealing the entire building, or as a minimum, one side of a building at a time.
Another aspect of the window wall replacement scenario that is critical to appreciate is it will require occupants to move out of their units while the work is taking place. As the existing building envelope is removed and replaced, likely on a floor-by-floor basis for each building face, the occupants will have to relocate while the work is carried out for anywhere from several weeks to a month. This will cause added expenses and disruption that will ripple through the building as the work proceeds. During the many months this replacement program is being executed, it is reasonable to assume it is not advantageous to put up a condo unit for sale, given the timing and cost uncertainties associated with a major retrofit.
In other words, management wouldn't simply slide a note under your door asking you to "Please move your couch as we will be replacing an entire wall of your unit today around noonish. Thx, Management"
42
Yes, but if you buy a house, you should be aware of the condition when you buy it. If an expenditure such as window replacement comes up, you can decide whether or not you want to replace it immediately or budget for it later - and live with the increased hydro bills in the meantime. Whatever, it's your choice.
You have no such choice in a condo. If a major flaw is discovered in the building or if a pipe bursts on the 37th floor, you are collectively responsible. If the board votes that you have to replace the entire window system and it's going to cost $50,000 per unit, you have no choice, either pay up or try to sell (and selling isn't an option in a building facing major repairs)
Regardless, none of these red herring arguments detract from the fact that this building boom has resulted in a plethora of sub-par, cheap-shit condos that are going to hold a lot of nasty surprises in the near future.
Ask yourself this: What do you think CityPlace is going to look like 20, 50 years in the future? Do you feel any sense of permanence when you walk around down there? There is already a class-action suit against one of the early buildings which has sprung leaks, another brand-new build has balcony wraps due to shoddy balconies. We never hear about most problems because people are deathly afraid that any publicity will negatively affect their resale value. Balconies explode... shhhhhh!
I'm not picking on CityPlace, a ton of cheap crap has been built over the last 10 years or so. Many questions will be asked.
Awful but expected. Repeating the same eyesore from 7 years ago. Conservatory Group wins the award again for ugliest new building in Southcore. Pug Awards considerations likely on its way as well.
Today:
Great shots today Udo. What kind of telephoto lens are you using?
Nothing too fancy. Just the built-in 25-600 mm Leica lens in the Lumix FZ200. Works pretty well if there is enough light.
I sincerely suggest next time the city approves a twin structure, especially one that's been existing for sometime, they should be due dilligence in assessing how much the old ones impacted the area.
It's really pathetic how developers are putting up cheap buildings at a very important area of our city that would be captured in Post-Card views to the outside world.
