UrbanAffair
At Trump, they are using RCS (Rail Climbing System) for Protection.
It is similar to this;
The system protects workers from falls, and from the elements. It also protects people on the ground from falling objects. On a building with a typical column + bay structure, it is most likely that the RCS is being used for protection, as there are different forms for pouring the columns (you can clearly see these in some of the latest pictures of Trump). This is not always the case, though, as RCS is also often used to form exterior shearwalls. The CN Tower was formed utilizing a RCS-system. There is a variation of the system to suit pretty much any building condition.
Identifying the difference can be difficult from afar, but it's a safe bet that the RCS at the top of most towers is primarily for protection.
Here is a basic example of climbing wall formwork;
The system is expensive to operate. If you're not utilizing the hydraulic-ascending RCS (which requires specialized workers) then you are forced to dedicate the crane to it's removal and replacement. This can be costly, and sometimes those cons outweigh the pros. In the case of Trump, the business of Bay & Adelaide and the possibility of lawsuit, likely made it worth the investment.
Awesome, thank you!
