Rascacielo
Today. One of the slanted columns on the ground floor is now encased in concrete.
Correct. They'll be covered in the "bronze-ish" cladding based on the renders and drawings.Likely cementitious fireproofing.
I'm sure Aritzea, or whomever the eventual tenant is, will want to have their own design team decorate their internal columns.I don't believe the "champagne" coloured cladding wraps into the retail space.
Are we even allowed to call these slanted things columns, since the ground floor flagship retail space is supposed to be 'column-free'?I'm sure Aritzea, or whomever the eventual tenant is, will want to have their own design team decorate their internal columns.
No, if you call them columns, Tim Cook will personally disable any Apple products you own.Are we even allowed to call these slanted things columns, since the ground floor flagship retail space is supposed to be 'column-free'?
Clearly they are canted support beams, not columns![]()
Based simply on logic, I would be more than shocked if that doesn't happen long, long, long before construction ends.iBeams? On a more serious note, I wonder if the tenant will fitout the space while construction is still ongoing for the rest of the tower (it's going to take awhile).
One would have to think they will do this, or use the upper parts of the podium as a staging platform or who knows honestly. But given you will probably have at minimum 2 years between full completion of the ground floor and completion of the upper floors here, and given there have already been delays, there is no way you dont open before construction is finished here.Yeah, but at same time I am not sure if any vendor would want to if the site remains a construction zone (unless they clean up the Bloor/Yonge corner and build a canopy along the lines of Aura).
