Found this tweet on Twitter:
@SkyJacked793: Front Street is starting to look like a street again in front of #UnionStation. There's a lot going on underneath. http://t.co/ifdx5NH9Mq
BtWGyk3CYAAv2k3.jpg:large
Plans for reference:
Source for that image: http://www1.toronto.ca/city_of_toro...pdf/front-st-ea-pic2-all-comp4-sec-orient.pdf
Work is under way to relocate the third rail to the opposite side on the Yonge-bound track. Some of the brackets and coverboard have been installed and sections of the third rail are lying between the running rails.
It obviously needs a good powerwashing, but I really like it. It looks clean and confident.'
Tho from a wayfinding perspective the LRT pictogram might be confusing for an out-of-towner. I know what that's a picture of, but I could see someone unfamiliar with the system not making the connection that that's the door you go through to get to the QQW streetcar.
It appears on the very left of the sign it says FIRE. Does this activate if there's a fire or alarm?
I'm assuming these doors will be gone when the moat gets enclosed a roof, right?
Unlikely. They will probably be kept for fire separation purposes. Maybe they will be changed to be the type of door that is kept propped open most of the time and automatically closed if the fire alarm goes off.
Ughh... why did they make the icon spacing so cramped on this sign. There's so much wasted space.
There are (as shown in the photos above) several triple sets of doors and two single ones (at either end). It appears that the spacing used was standardised for both kinds of door - looks OK on the single doors but a bit crowded on the triples. Hardly a design disaster but ...
