Riverdale Rink Rat
So Dufferin and Bloor (Dufferin Mall) is suburbia I suppose? You mention how density focuses at nodes, how is this different than much of the Yonge line where density drops off away from the stations?
And those condos weren't there before the subway was there either...I'm not saying that Sheppard should get a subway because it is dense. I'm saying that if density was the only factor in regards to building a subway, then there is precedent to suggest that Sheppard is dense enough to support one.
Would you be so kind as to say clearly what you are advocating? I think (correct me if I'm wrong) that you're trying to weasel around to 'we should continue to have Sheppard underground.' If so, stop. Sheppard should never have been underground, and to compound the mistake would be egregious.
Dufferin Mall is a royal mistake. Yonge is the spine of the city, and, while you are technically correct that the condos came after the Yonge line, given the decades-long time gap, I'm going to go with 'sort-of correlation does not imply causation.'
Agincourt is a friggin' SUBURB.
