TheTigerMaster
Superstar
I assume they're using a spring loaded mechanism just like the trolley poles. Meaning that the pressure of the overhead wire will push the panto lower.
It's situations like this that make it look ridiculous to worry about the height of the Union Station trainshed, and whether or not it will support electrification.
Pantograph operation is going to work through this tunnel, and that is much less clearance than we see at Union.
In fairness, we're dealing with "only" 600Vdc here, rather than the 25kVac system proposed for Union Station. The required clearances around the electrified wire is several times less on the streetcar network than with the potential mainline system.
For some reason this forum is fascinated by pantographs.
So they'll just jump out and manually change the switches then ...
Probably because although we are all fans of the TTC and its streetcars, it is well time that the system took the leap into the 21st century; and that operators didn't have to jump out into the middle of an intersection to re-wire a trolley pole and we all got to our destinations on time.
21st century...??? try late 20th......TTC has only begun to dig their heads out of the sand
It's been a long time but I think the additional clearance is something around 90mm IF nothing else changes.
From the wire? Much, much more than that.
About 10" from the wire in all directions is seen as the minimum safe clearance limit, when energized with 25KV.
And once the various factors for sag of the wire, they like more than that.
The 90mm number was additional clearance from 600V dc in the above picture of King Street to 25kV ac using a similar overhead rail design.
The statement earlier was that 25kv required significantly higher clearance than the picture so I tried to put a number on it. It's been 15 years since I did anything related to electrical engineering; it certainly could be wrong.
There is no sag in overhead rail. Catenary would have plenty of additional issues.
Agreed 100%. But none of us should blame the TTC or its staff. The city, and the bungling inept TTC board and city council are responsible for this mess. For the whining about not receiving handouts from higher order government. For the lack of direction and courage. For the failure to lead, and the failure to demand and and the failure to be prepared to pay for - a truly modern, strong transit system.
