I'd much rather they focus on improving streetcar operations than building LRTs that won't end up faster than the currently existing buses (I'm thinking of the Eglinton East LRT here).
I think it's nuts that we have what could be high functioning rail-based network, but it's hampered by so many factors. Whenever I'm in Warsaw, I find it fun to ride the trams. People complain about removing stops, but I would say their stops are much further apart than the TTC's and they have just as much elderly there as here, if not more. And they manage just fine.
I think there needs to be a coordinated effort to bring our streetcar system up-to-par with the best tram systems in the world. Make it a project like a subway project with dedicated funding.
All those switches we constantly keep hearing about getting blamed? Replace all of them. How much can it possibly cost? A few million? Still much cheaper than a subway. To be clear, I have zero clue how much it would cost.
They had to upgrade the wires when the new streetcars came with pantographs, and that's mostly done now. It wasn't done all at once, so how long would it take to upgrade these switches? Are they doing it whenever they do track replacements? If not, why not?
Those 21st century double-point switches and associated controls would be more expensive than the 20th century single-point switches. So the auto-addicted politicians and bureaucrats will say "no".
Walter you keep saying this but those who actually know about such things have said that the type of switch is not really important. Most that are not working are fine mechanically but have electrical issues.
Then fix the electrical issues properly. Or are they running with the "go slow" orders just in case?
I dare say there's no danger of the slow zones being corrected any time soon.
That's kinda stupid the way they present it.
If you want to run a service at a certain level you need to budget for the maintenance.
It's like driving your car. You need to maintain it to drive it. Relative to the distance.
Around 12:30 there was notice of some major issue, subway driver said a cracked rail northbound, probably between Lawrence around York Mills. Single track operations while they repair it, though I wonder how long that takes and if it'll be done before rush.
Before TTC gave notice of delays between Lawrence and Finch though the service alert is now between Bloor-Yonge and Finch.
Remember those days of the TTC saying that they've learned their lesson about hydraulic oil leaks, and how they would ensure this kind of thing would not happen and.......
The issue is maintanence and the age of the work cars.
The fact that it takes 4-5 hours to clean this up probably means they are doing it manually with a mop a bucket.
Also if it is found that the cause was a hose that was damaged or in disrepair it means that they have not learned their lesson and are complacent. In other words it's all talk, and nothing has changed.
It was near Old Mill.
Depending on where it is and where any potential drains lead to it is possible they had concerns that some hydraulic oil got into the Humber. That would lead to the MoE getting involved alongside the MoL.
If you have a multi-ministry investigation it would take alot of time to investigate.
Another factor to consider is the gradiant. It is downhill towards Royal York, any leaked fluid would run down towards the lowest point.
How many liters of fluid are we talking about?
