 9.8K     0
 5.6K     0
I'm not a fan of the terms 'light metro' and 'light rail' as a general rule, I only used them to differentiate between the Hitachi trains and the traditional rolling stock of the legacy network.
One of the reasons I'm not a fan of it is because it is so vague and broad that it can be moulded to whatever you want. When the H5s and H6s were retiring a decade ago, there were plans to send them to Lagos, Nigeria, for use on their new 'light rail' system. Our cars are usually lighter than those that run in New York, and even New York's are feather light compared to freight locos on the continent, which is what I consider to be actual 'heavy rail'.
But if one looks at new build LRT lines, there are some that differ very little from what we are trying to do with the Ontario line, so you're not, strictly speaking, incorrect. And then there are LRT lines which are just grade separated streetcars, like Finch West. Light rail was originally marketing wank used to refer to the revivals of the 'streetcar' back in the 70s and 80s, that couldn't call them 'streetcars' because that was still something of a dirty word (still is, if you read the comments on any article about them here, too). It's become obfuscated beyond reasonable use.
Okay I understand. But can you or someone else please clarify to me. Will the LRT lines currently under construction (Crosstown, Finch West, Hurontario in Mississauga) travel at a faster speed than say the St. Clair, Spadina streetcar routes? I understand streetcars in Toronto have to deal with speed restrictions when they share the road with cars, but is this the case when the (proper) streetcars have their own dedicated tracks?
That depends on the operational rules that are elected for use on the lines in question.
If you watch any video from this gentleman in Prague, you will see that despite there not being complete grade separations, the tram clips along at a fair pace. The Spadina and St. Clair lines could do the same, but 3 things hold them back:
1) TTC paranoia, based on previous incidents, mandating rules like having to stop and visually inspect every switch before you cross it, and then travelling across the entire switch at a reduced speed (someone else will know exactly what it is, but it should be in the neighbourhood of 10 km/h); or one tram having to yield to the other on any track intersection (northbound and westbound cars yield to the southbound and eastbound cars)
2) a lack of transit priority, requiring streetcars to stop at a red light, cross the intersection, and then stop again. This massively slows down the 510 streetcar especially
3) Stops being too close, which is not the case on any of the suburban lines
b) because different vehicles were built at different times, trying to do a wholesale replacement would result either in vehicles being prematurely retired because we have new ones now, which is a waste of money
They had no qualms about prematurely retiring the H6s in order to standardize the fleet (I'm almost certain they would've done the same thing even if they weren't lemons), and PATH replaced all PA1-4s even earlier, by 2011, in order to have only 1 model (PA5), despite the youngest PA4s being barely over 20 years old and not being lemons.
or in vehicles having their lives artificially extended, possibly beyond the point of feasibility, because you don't want to waste money by retiring something on another line that is only 2/3rds through its lifespan. For example: the TRs will be life expired in 20 years, the T1 replacements will come online in, say, 10 - how would you possibly replace both at the same time?
Only if the T1s are life-extended to last until 2040 (Scenario 3 in the most recently published document), then it would absolutely make sense to replace both the T1s and TRs at the same time since the oldest TRs will also be 30 (why give the TRs a life extension instead of simply expanding the order of new cars that would be arriving in greater numbers by then?). Of course, they didn't have the foresight to look that far ahead and outline that as an option in Scenario 3.
The term light rail / LRT should refer to any line with tramlike rolling stock, simple as that. If it's not a tram, it should not be classified as light rail, no matter how "feather light" it may be. The term light metro makes sense when referring to something like the SRT which is basically a subway line with smaller trains and possibly customized technology. I disagree with classifying OL rolling stock as a light metro rather than a heavy-rail subway, much like the IRT isn't classified as such despite being smaller than the BMT/IND.
instead of the traditional RT-75 style rolling stock that we are well used to in Toronto.
Nitpick: technically the TRs are not based on RT-75, only the M/H/T cars were. But ofc the TRs do have the same dimensions.
I see no point in a primarily overground LRT line using anything but line of sight operation.
Shhh don't let the manufacturers of self-driving cars hear that 🤣
They didn't standardize the fleet, there are still 2 models in circulation, both of which are different and require their own parts inventory and maintenance practices.
There was no plan to do this. The H6s were retired only because federal money happened to become available to exercise the option order. Had this not occurred, the plan was for the cars to last until 2019.
I was referring to retiring the TR and T1 replacements concurrently, not TRs and T1s.
If there was a life extension done on the T1, then retiring them in tandem with unrefurbished TRs would of course have made the most sense.
Well, you can call it whatever you like, but don't complain if people have no idea what you're talking about.
Calling something light rail based on its weight is based on an objective, easily verified property of the object in question. Any other property, such as design or aesthetics, how frequently it runs, how many people it's capable of carrying, is either superficial or too fickle to pin down. And how would you distinguish subways from freight locomotives? Suggesting they belong in the same category of machine is misleading at best, an outright lie at worst.
A large part of the problem is that you're trying to deal in absolutes when there are really aren't any to be found.
"Light rail" is named as such because of it's relative lightness in capacity to "heavy rail" metros. Historically the vehicles were built lighter than metros/subways, but in the modern parlance the weight of the vehicles is largely irrelevant.
"Light metro" is marketing wank and really has no bearing on anything whatsoever other than sounding hip and trendy and new. They can be built to the same capacity as "heavy metros" with some slight-of-hand, and are no lighter (or heavier) in weight or construction.
As most of Line 5 is grade-separated, with a vehicle capacity similar to Line 4, and a more frequent maximum frequency, then is Line 4 Sheppard also light rail?
Perhaps most of Line 5 isn't light rail.
  • Like
Reactions: T3G
But this still doesn't solve the problem that we don't have enough cars for the Scarborough extension nor do we have any rolling stock for service expansion.
Can they not take 4 TR Train sets and run them on Line 2 during rush hour to off set the shortage of T1's when the Scarborough subway opens?
They did standardize it at least partially, having only 2 models is less than 3 or more, especially with only 1 model per line.
Well, if it weren't for them being lemons there shouldn't have been a need to even offer the option order, had they been reliable they shouldn't've had second thoughts about running them until 2019 and possibly until now, at which point there would be 2 models ripe enough for replacement...
Well, that is definitely not a realistic scenario, given that the T1 replacements will come at least 20 years later than the TRs (as of now, the earliest they are expected to show up is 2030, albeit with a more tight delivery schedule of 3 years instead of 6). Perhaps, with a 20-year difference in age, there would also be more technological advances, rather than keeping them almost identical to the TR.
Pretty sure most people do, and most people interpret all those terms in more or less the same way.
But weight is a continuous spectrum, and so there will always be borderline cases or even overlaps.
Not more misleading than saying a LIRR M7 is the same category of machine as a freight locomotive?
as they don't connect to any other line in the network (Finch and Eglinton, and the Ontario Line, notably)
That is one of the things I hate the most about the latest trend of building new lines here. While I fully agree that having one standardized fleet across the entire network is not the best idea (not just from a railfan perspective), I absolutely will die on the hill that having one single large integrated network is in every way superior to having every individual line completely severed from every other line, which seems like the most shortsighted, poorly-planned decision possible.
The OL, at the very least, might have a non-revenue spur connection to the CP mainline (although it would make far more sense for it to connect to lines 1, 2 & 4 and have interoperable rolling stock).
The term light rail is just a concept which differs vastly with different implementations.
It's just a modernization of streetcars adopted for faster travel. It is the North American implementation of German Stadtbahn systems.
Line 5 is light rail cause the technology isn't design for linking up more than 3 LRVs together while Line 4 trains can definitely be built to 8 to 12 car lengths if they want. However Line 5 uses ATC/ATO which is not part of a light rail system. So it's really a hybrid system.
Hybrid for sure, but what other than platform length (and presumably current software) precludes making longer trains?
  • Like
Reactions: T3G
Who do you think offered the option order to whom?
The TTC contracted with Bombardier for X amount of cars delivered over Y time frame, with the option to receive an additional amount of cars if they were pleased with the product. It is then up to the TTC to decide whether they want it (and then up to the feds, to decide how generous they are with the purse strings). How satisfied they are with the current rolling stock has no bearing on the existence of an option offer whatsoever.
As a counter example, the order for 204 Flexity cars had an option for an additional 60. Due to a variety of circumstances, that option was not exercised, and now we are paying more per car for 4604-4663, than we would be if we had taken the option when it was made available
Read back to the very start of the conversation, and you will see why I mentioned TRs and T1s retiring together. At no point did I say it was realistic.
And aesthetics or passenger carrying capacity isn't?
A car that weighs 20k kg empty will always weigh 20k kg empty. That doesn't change. But passenger carrying capacity can change - if you couple 10 crosstown cars together, you will have greater carrying capacity than a current TTC subway train. If you coupled 100 of them together you'd have a higher carrying capacity than the GO train. How's that for "light" capacity rail? (Note: this does NOT mean I would ever expect to see 100 crosstown cars lashed up together, just pointing out how capacity is a very unstable number that can change based on number of cars coupled together, as well as other things like service frequencies).
Aesthetics also change. You are a purist who thinks trams should be distinct from subways, because reasons. There are purists who grew up on the PCCs and think that the only real type of tram is the single bodied, corner driver seat model that doesn't view these new slinkies as being real trams. Someone who wasn't alive at the turn of the millennium thinks those singled bodied cars are as ancient and outdated as if they had been operating in ancient Egypt.
Perceptions are fickle. Hard facts like weight are not. And a streetcar, being a nimble, quick, electric, high capacity transit solution has a lot more in common with the subway, another nimble, quick, electric, high capacity transit solution, than it does with a VIA or GO or CN train. So no, I do not see any compelling reason to call subway trains anything but light rail.
Then a 2–4-car GO train is also "light rail" (since we're gonna blur the lines between LRT / light metro / subway, why stop there & not go a step further? why not blur the lines between local & regional transit? if there are no absolutes/purists in different forms of urban rail transport, why would there be in local vs regional vs higher-order transit?).
This is why:
There are purists who think that the only real type of tram is the single bodied, corner driver seat model that doesn't view these new slinkies as being real trams.
Well, they'll get no disagreement from me there, lol. In fact, the main reason I don't think much of LRT in general is precisely because it most often tends to use "slinkies", which is why the term LRT is automatically associated with them. I can't think of many examples of LRT systems that use single-bodied trams. So, defining LRT as using "slinky" trams seems pretty clear & concise. Point being, I profusely disagree that a slinky tram and a heavy rail subway car can be lumped into the same category of vehicle. And yes, I'd sooner lump subway cars into the same category as freight locomotives (both being single-bodied & having higher ground clearance), which Europe doesn't have a problem with.
Simply being "pleased" with a product is in itself not a compelling enough reason to order more of the same thing. Why order new vehicles unless you're planning service expansion and/or have vehicles needing to be replaced?
I did, and the point of the conversation would be the same whether you use "T1 and TR" or "TR and T1 replacements". The former example would just make more sense at this time, rather than talking about replacing trains that have yet to be conceived.
Okay, here is where it gets absolute.
The mainline railways - CN, CP, VIA, GO and the like - are all considered heavy railways. And there are legal and regulatory definitions that reinforce this.
And thus, anything rail-based that can't intermingle with them - subways, streetcars, etc. - are considered light rail.
But it's also context-driven, too. If you're talking about transit, with transit professionals, "heavy rail" in most cases something akin to our subway system, not a GO train. They will use other terms, such as "commuter rail", to help define them versus the other modes.
Confused yet?
Last weekend I finally spotted security guards on the train, on Line 1. There are so many security guards in this city that it took me a moment to confirm that they were TTC-contracted guards, and not just some guards commuting to their shift.
