 6.2K     0
ttc.ca/Service_Advisories/Route_diversions/501_Mar_TM.jsp
501 will divert this weekend via Church, King, Parialment EB, and Parialment, King, Church, Richmond, and Victoria WB. Nice chance to see CLRVs on King!
Where exactly are they doing the track maintenance on that short stretch of Queen? Is there a particular problem spot from something gone wrong over the winter?
Last year they replaced rail at several points on both King and Queen, usually near stops which apparently cause additional wear or strain. This is a normal 'summer activity' and I assume it's what's going on here.
The problem spot would likely be the eastbound track approaching Queen and Parialment, you feel a huge bump as the streetcars go over it
Ah yes. I don't pass that point on the streetcar, but I recall seeing overhead signs for a slow order there right now.
This is on TTC construction pages:
What we are doing and why?
Starting at 8 a.m. on Saturday, March 23, TTC track crews will be conducting a localized rail repair on Queen Street East, near Berkeley Street. All work activities will be contained within the track area and will include minor breaking and removal of concrete to expose the rail, replacing a section of existing rail with new rail, and placement of new concrete.
Traffic and pedestrian restrictions
  • Traffic will be reduced to one lane in each direction through the work zone for the duration of the work.
  • On-street parking will be restricted through the area to create a safe work zone for the crew.
  • The location and length of the work zone may prohibit left turns.
  • The lane restrictions and work zone will be cleared by Monday morning around 5 a.m. after the newly placed concrete has cured adequately for road traffic.
Noticing that there were some discussions in the other threads about future streetcar orders. I ventured onto Finland's Skoda-Transtech site to take a look at the marketing material for the ArcticTram after seeing videos.
http://www.transtech.fi/railway/low-floor_tram
What really piqued my interests is whether Skoda-Transtech would be interested in participating in bidding for the future TTC order(s) now that Alstom-Siemens is establishing a base here. The ArticTram seems well suited for our network albeit with some modifications. And they incorporated a traditional free-turning bogie/truck unlike all the rigid trucks that modern low-floor trams use.
ARTIC™ is excellently suited for tram track networks with several small-radius horizontal and vertical curves. To comply with current standards, the entire tram is equipped with a low floor. Thanks to its ingenious structure, the tram combines a full-length low floor with a traditional freely turning bogie under the car, similar to articulated trams.
The flexibility of the three stage suspension system and the articulation solution between car sections adapt to the shape of the tram track and maintain even wheel loads and good passenger comfort regardless of the condition of the tram track. The bogie structure efficiently dampens sharp shocks from the tram track, particularly in the winter. The tram runs smoothly and silently even in sharp curves and over switches, which have posed problems for traditional low-floor trams. This means that wear load on the track and wheels are minimal.
ARTIC™ takes the demanding climate conditions of the North into consideration. The carefully designed platform structure prevents the packing of snow and ice. The accumulation of moisture and condensation water into car structures has been eliminated with meticulous heat insulation and water barriers and moisture dissipation.
Technical Data:
http://www.transtech.fi/railway/low-floor_tram/technical_data
Wikipedia:
https://en.wikipedia.org/wiki/Artic_(tram)
Just some fun reading material for a Sunday evening.
In the Report to TTC Board on the King Street Project they recommend adding a curve at York:
Streetcar track network enhancements: improving the intersection of York Street and King Street by adding an additional east-to-north movement that allows for more routing options for diversions or adjustments. Layby tracks within the pilot area may also provide an opportunity to provide greater service resiliency with standby vehicles.
It would also add flexibility if they built/rebuilt the tracks on Adelaide, at least from York to Victoria
Technical Data:
Wikipedia:
Whoa! Incredible 'heads-up'. Before even accessing the links, I see the motors on the *outside* of the bogie, which is a brilliant rearrangement of conventional thinking. As well as drive and height advantages, it would also shift the centre of gravity to a much wider stance...akin to standing on the bottom of a ladder with a foot each side to spread the weight and stabilize the weight above.
I'm off to do some reading!
Addendum: Took some time to find more detailed info on the bogies and the "steerable axles" (which is what I thought they meant, but it might be terminology used mostly in the West), and there's a number of really sensible engineering features to these vehicles. Excellent multi-page pdf:
https://www.hel.fi/static/hkl/artic.pdf
Btw: I first thought how 'Dune' (the movie) the vehicles looked with their upright windshields, but it's in fact for excellent utilitarian reasons it's done, all explained in the pdf above.
One word for this in light of the fiasco now ongoing in Toronto: "Envy".
It would also add flexibility if the built/rebuilt the tracks on Adelaide, at least from York to Victoria
I quite like the idea of layby tracks; but I think they need to be oriented, of the correct length for, and have the proper connections to support them as passing tracks as well.
That means, as opposed to be off-street, or on a side street, they need to be on King, connected to/from King, and allow for easy-flow passing.
This is important so that the empty car in the pair/trio be allowed to jump ahead and serve the overcrowded stops.
Doing this at even 2 points on the line per direction would be immensely helpful to service.
Its an idea I've pushed before. Glad to see it gaining traction.
Now, about the idea of having mid-route 'hold signals' to space out pairs/trios that form............
Best way to do this is to stop it from being necessary in the first place: ATO. And with ATO, those 'lay-by''passing' tracks could also be timed stopping tracks, looped closer to the curb, to allow 'express' (only major stops) cars to go through unfettered.
ATO (Automatic train control) allows many higher functions to happen.
Autonomous trams demonstrated in public | Rail Engineer
https://www.railengineer.co.uk › Light Rail
Dec 10, 2018 - Home Light Rail Autonomous trams demonstrated in public .... This solution uses an ATO over ETCS L2 solution from Ansaldo STS, combined ...
[PDF]cbtc for tram - SYSTRA.com
https://www.systra.com/IMG/pdf/systra-cbtc_oct2015-tram.pdf
for enforcing safe tram separation from other trams, road vehicles and pedestrians ... by efficient cabsignal HMI (“in cabin signal”) and/or ATO assistance. When it ...
Autonomous transportation - Alstom
https://www.alstom.com/autonomous-transportation-smart-and-safe-operations
The ATO controls the train speed to optimise both energy saving and driving ... experiment related to the autonomous stabling of trams at the Paris tramway line ...
Mounting the motors on the outside of the truck sideframes has been done for many years, as there are virtually no other places to mount them and maintain a fully low-floor car. In fact, if you read up more on the Artic trams you'll find out that they're equipped with an off-the-shelf Voith drive package.
The Artic does not use steerable axles. They use traditional, rotating bogies at all four points, which up to that point was highly unusual with a tram with a 100% low floor.
It should also be noted that all of the Artic trams built up to now have been for metre gauge track. There has been an order for trams for a standard gauge system, but it is also for a more "traditionally" designed low-floor tram, and not this version of the Artic - even though it will be branded as such.
It depends on your definition of "steerable". There's both passive and active. I'd use the term "steerable bogie" or "wheels" save that this model of bogie has continuous axles. The forward lead bogies (one each end) at least have a sense mechanism for the radius of turn to adjust operating parameters. I'll try and dig more out later on that.
There's an excellent engineering discussion on low floor tram bogies here:
http://www.transoneleng.org/2015/20151c.pdf
And one of Voith's pages here:
https://stories.voith.com/most-liveable-electrified-helsinki-51415/en
and:
http://voith.com/corp-en/drives-transmissions/gear-units/gear-units-special-purpose-vehicles.html
http://voith.com/corp-en/news-room/press-releases_75729.html
No, it doesn't.
A steerable axle is one which it is able to rotate and continue to be perpendicular to the rails.
A truck can steer, but unless it also has steerable axles, the axles will never be truly perpendicular to the rails in curves.
When it comes to bogies, the term "steerable" is very clearly defined.
OK, then define this:
The tram runs even the sharpest of curves and the steepest hills and valleys smoothly. It is also the first tram in the world to effortlessly master any combination of all three. The multidirectional articulations and freely-turning bogies ensure good passenger comfort and long vehicle structure service life in all conditions.
Helsinki's New Tram - Transtech
Note:
The bogie of the tram combines proven high-quality solutions with the latest low-floor technology. The bogie structure is based on the articulated bogie solution, which has been successfully used in rail vehicles for decades. The bogies consist of, among others, traditional wheelsets with continuous axles, coil springs in secondary suspension and large wheels. These highly reliable solutions combined with the low-floor structure, short wheelbase, very flexible rubber elements in wheels, and compact traction chain result in a tram that runs reliably and cost-efficiently in the most demanding conditions for years on end. The advantages of the bogie solution include excellent running behaviour, even in the most challenging track conditions, its light weight, minimal wear and tear on wheels and rail, and low life cycle costs.
Emphasis on "very flexible rubber elements in wheels". That's for radius compliance as much as vertical undulation absorption, curving performance and dynamic stability.
There's lots of detail here:
https://www.researchgate.net/figure...bogies-with-independent-wheels_fig1_267830130
And to those wondering what an "articulated bogie" is:
Articulated bogie
An articulated bogie is any one of a number of bogie designs that allow railway equipment to safely turn sharp corners, while reducing or eliminating the "screeching" normally associated with metal wheels rounding a bend in the rails. There are a number of such designs, and the term is also applied to train sets that incorporate articulation in the vehicle, as opposed to the bogies themselves.
If one considers a single bogie "up close", it resembles a small rail car with axles at either end. The same effect that causes the bogies to rub against the rails at longer radius causes each of the pairs of wheels to rub on the rails and cause the screeching. Articulated bogies add a second pivot point between the two axles to allow them to rotate to the correct angle even in these cases.
https://en.wikipedia.org/wiki/Bogie#Articulated_bogie
Suitable for demanding conditions Transtech’s ARTIC® is excellently suited for tram track networks with several small-radius horizontal and vertical curves. To comply with current standards, the entire tram is equipped with a low floor. Thanks to its ingenious structure, ARTIC® combines a full-length low floor with a traditional freely turning bogie under the car, similar to articulated trams.[...]
http://www.transtech.fi/download/103/low-floor_tram/pdf
