So...marginal benefits, low priority, very expensive...have we come to a satisfying conclusion yet?
I did 4 pages ago... Suicide doors it is! Or maybe a bunch of power-washers. Either would be a better use of money.
If I understood correctly, you're referring at the parts of the subway network that do not consist of the wooden railroad tie, right? Such as the stations for example?To add 2 feet to the floor thinkness you either need to reduce the train height by the same or drop the floor down which will be pretty darn tricky since much of Toronto's subway system is below the watertable (see muck floods during Sheppard construction for just how difficult).
I vote standard gauge the existing network. Expensive and no benefit other than matching the soon to be cancelled standard gauge Eglinton LRT.
I vote power washers.
IIRC, Environment Canada forced TTC to stop power washing many locations a decade ago due to the drainage/sewer configuration of the stations. TTC sewers are not treated and run-off into the lake or something like that.
See, I don't agree with this. Yes, power washers do use soap, but really, the run-off from the roads is FAR worse than a little soap in the water. Do it once a month, it's not going to kill the eco-system.
They're going to cancel this in favor of a subway?I vote standard gauge the existing network. Expensive and no benefit other than matching the soon to be cancelled standard gauge Eglinton LRT.
They can use pumps and tanks to catch the soapy water before it enters the drain. The equipment would then be hauled away by train. There might also be biodegradable solutions. I image there are a variety of options for power washing, though it may take some initial out-of-the-box thinking.
Just a note on washing. The MoE ordered it stopped, not because of the cleaning solutions going in the drains, but because the break dust is toxic. It is also quite difficult to wash off with water. It's not like power-washing dirt on your car.
