 6.2K     0
Shovels in the ground on the rail line to Churchill.
2oXoiOc
Double track and electrification to be preserved on VIA ROW. Quite a bit of doubling to do including bridges before reaching that crossing though
Comparing Toronto-Montreal and Seville-Madrid Passenger Rail Lines
by Paul Langan, published today.
When you compare the two lines, the populations are relatively the same but then the tragic state of inter city passenger rail in Ontario/Quebec is very clear.
The article does not talk about the Euro 5b yearly operating subsidy for Spanish rail. Plus the European capital grants. Plus the decline in rail traffic in Spain.
Spain is an example of this, but it goes further than just Spain, which like Ontario, was politically driven for int'l sports extravagances (although UPX is far from being high-speed, it's pretty slow even by airport shuttle standards)
EU Observer
By PETER TEFFER
BRUSSELS, 26. JUN, 11:32, 2018
The EU has spent €23.7bn on high-speed railway projects since 2000, but this co-funding was of "low added value", the European Court of Auditors said in a report on Tuesday (26 June).
It said it was "very unlikely" that a target for tripling the length of Europe's high-speed rail network by 2030 could be achieved, and that a pan-European approach is missing.
"The decision to build high-speed lines is often based on political considerations, and cost-benefit analyses are not used generally as a tool to support cost-efficient decision-making," said the report.
The researchers audited Austria, Germany, France, Italy, Portugal, and Spain – who together received 83.5 percent of all EU funding for high-speed railway lines since 2000.
The report's findings are highly relevant, not only because they raise questions about whether EU funding was spent effectively, but also as rail travel is being touted as a more climate-friendly alternative to flying.
The auditors found that domestic high-speed rail was competitive compared to aviation, but did not look at the difference between railway travel and low-cost flights between EU cities in different member states.
They concluded that there is no European high-speed rail network, "only a patchwork of national high-speed lines, planned and built by the member states in isolation".
According to the report, there was no proper coordination across borders, despite international agreements and EU legislation.
The European Commission set a target in a 2011 'white paper' to have a European high-speed rail network by 2030 that is more than 30,000 km long.
The auditors noted however that by the end of 2017, only 9,000 km of high-speed lines were operational, with 1,700 km under construction.
"We consider it unlikely that this target will be reached, because it takes around 16 years for high-speed rail infrastructure to be planned, built, and to begin operations," said the report.
In an advance response, attached to the report, the commission said that it still believed the 2030 target can be met.
"The commission remains committed to the conclusions and the identified measures following from the strategy outlined in the 2011 white paper and continues to put forward and implement the actions necessary to fulfil the objectives set out in the document," said the EU executive.
The court of auditors – which is not an actual court – noted however that the commission has "no legal tools and no powers in the decision making" to make sure that member state governments carry out the required plans to achieve its goal.
"We found that the EU's current long-term plan is not supported by credible analysis, is unlikely to be achieved, and lacks a solid EU-wide strategic approach," the auditors said.
The EU's financial contribution to the high-speed railway projects was "a small fraction" of the total investments member states made.
The court noted that high-speed rail projects tended to be marred with delays and overrun in costs.
Eight of the thirty projects which the court audited were delayed by at least one year, while five of the ten lines audited had experienced delays of more than a decade.
A stretch of 267km of high-speed railway between Germany's Stuttgart and Munich, for example, was estimated at €1.8bn, but ended up costing at least €13.3bn – with the line not completed yet.
The estimated costs for the 'Stuttgart 21' railway station was at €4.5bn in 2003, €6.5bn in 2013, and €8.2bn in January 2018.
"For this project, because of unrealistic initial cost estimates for tunnelling in a densely-populated city centre, and insufficient assessments of geological, environmental and local community cultural heritage aspects, construction costs have soared," said the report.
The original plan said that the Stuttgart construction works would be done by 2008 – they are now estimated to be finished by 2025.
Obligatory layovers
The auditors also noted that differences in national railway legislation are still causing obligatory layovers at borders – something which they already warned about in 2010.
When travelling from France to Spain, travellers have to change platforms when crossing the border.
"Because most of the section between Bordeaux and the Spanish border is not a priority for France, infrastructure at the border remains antiquated, incompatible and poorly suited to a modern high-speed rail network," said the report.
https://euobserver.com/economic/142191
See also:
Europe slams Spain over “inefficiency” in high-speed railway construction
The EU’s spending on Spain’s AVE rail network exceeded the combined amount funnelled to France, Germany, Italy and Poland
https://www.ara.cat/en/Europe-Spain-inefficiency-high-speed-construction_0_2040995975.html
The answer for Ontario and Quebec lies in VIA HFR.
My wife has to spend 2 hours longer in London on Friday than she wants to because VIA can’t run a train leaving between 5-6 for Toronto. A HFR would be nice but cutting time sitting around waiting to leave would be a lot cheaper and quicker to implement
If the PCs kill HSR, HFR to London would be great. Sorry about your wife, but as a student I did find overall that VIA to Toronto had a decent amount of options daily, maybe not just at that time.
