In short, spending further public money on the Kingston Sub is an even more short-sided (i.e. suboptimal) HFR configuration and an even less right solution. But maybe I'm just failing to see the strategic plan behind your argument, which somehow shows a way to make the billions of investment into the Kingston Sub you propose future-proof and HSR-ready...
To be clear, I am not arguing for the Kingston line as the choice for HSR. I am arguing it is a better interim solution for now, recognising that whatever we build now will be an interim network that will be abandoned as a “stranded asset” once there is an appetite for a “next step” advance.
My preference to stick with that route is because
- The timing of “what comes next” is uncertain and may be further away than we believe. So the “interim” solution has to be good enough to serve us for a generation, or more.
- I do not see the proposed interim Montreal-Toronto service as adequate for up to 40 years, and indeed may burn a bridge by removing appetite and reinforcing the use of other alternatives for travel on that route. That elusive 4-hour timing is a dealbreaker in my view, we need it now. These end point are Canada’s two largest cities, after all.
- The “next step“ after HFR may only be 200km/hr UK-ish non electric HST. We may be 40 years or more away from a 300km/hr TGV-ish solution. The UK is outgrowing HST, but it served them well. Our vision should not fixate on high end HSR as the next step.
- While the Kingston is not 300km/hr capable, I see it as 200 km/hr capable....., whereas the Havelock line is clearly not, for the same money. So it’s a better mid term investment.
- There is stranded public investment already in the Kingston line. Its current level of grade separation (which the parallel CP line does not enjoy, let alone the Havelock). was predicated on the frequency of higher-speed passenger use. And there is the $400M trip,e tracking, which CN might not use after HFR.
- The Lake Ontario corridor requires a transportation infrastructure that is not merely de minimus or sufficient for 2020, but adequate for growth in population and enabling substantial movement away from highway travel. Eastern Ontario is the logical place for Ontario to develop as the west-of-GTA areas fill up. An assurance that VIA will not abandon those towns is not sufficient commitment to grow that service commensurate with those communities’ needs.
- All the arguments that the Lake Ontario local service can be assured on CN tracks assume resolution of the very freight conflicts that are forcing VIA to move away. What if in 25 years, CN’s freight business has doubled? At the same point where population is growing along the Lakeshore? The local service can only encounter more restrictions over time. Investment now in the Kingston line might bridge the gap.... after all, VIA’s 2008 capital plan wasn’t wrong, it just didn’t deliver enough of the additional tracks that were planned. Co-production can be a constructive part of that, with no adverse impact to freight or CN/CP investors.
There are two opposing realities in my argument that I can’t overcome, I will admit
- Public, investor, and political appetite for investment in rail passenger is so weak that we have to grasp at any attainable proposition that attracts investors, regardless of how much of the overall transportation needs of the Ontario-Quebec region are served.
- The desire to remain hands-off to freight railways is apparently immovable, so VIA has to find its own path somewhere else. Those options are limited and costly, some are out of reach.
So long as these realities remain, then VIA is better served to just get on with HFR. But that’s not a good transportation strategy.
