D
Duck
Guest
Before anyone asks, the old wooden tied track will be removed and replaced in the next little while.
That is indeed what DC means in Waterloo.I don't know what DC is [...]
DC - do you mean Davis Centre aka the University of Waterloo stop?
I don't know what DC is but the tracks end right now about 50m North of the Waterloo Park ("Seagram") station. The area is now all graded for the platforms. There is a lot of detail track work at this one for the gauntlet because it happens before the crossing, so there will be 6 rails (not 4) cutting through the crossing.
The Research & Technology platform is starting to take shape and the gauntlet track switches (but not the rails) are in place. The platforms at Gauckel have forms up and may be poured by now.
So far this summer, there's been a lot of earthworks for the two stations, and their rough elevations are in place. They're still using temporary track to maintain functionality of the spur, and as Duck has said, some complicated trackwork has just started construction recently. Once the gauntlet tracks are built for each of the stations, the second track will go in rather quickly, as it will be much simpler.
The station platforms themselves are yet to be worked on.
Lived in KW for near 20 years, and often called it the Davis Centre DC. That's what it's shown as on the UW maps. And the library homepage - http://www.lib.uwaterloo.ca/index.phpLived in KW for 15 years and that's the first time I've ever heard it called "DC"
Any visible work being done for stations at DC and Waterloo Park?
New track going in at Waterloo ParkAny visible work being done for stations at DC and Waterloo Park?
BUT, the surface of those track "basins" seem to be loose gravel. Are they not going to be using the same cement that they've been using for the road crossings? It's seriously going to be just loose gravel like the CN spur lines that they've been realigning the tracks to? That's kind of gross looking for the middle of the city.
I think that's just a factor of poor labeling. It's pretty much assured that any in-road sections are going to be paved with concrete, to allow emergency services access.
The construction method was decidedly different from what we've seen elsewhere on this forum for TTC streetcar tracks.
I recall seeing that for the TTC, there's a concrete later poured first, then the foundation of the tracks is embedded in a second layer, and then a final layer to bury the rails.
Here, there was a single concrete pour, encompassing a rebar-grid, above which are the rails on some light foundations. One big thick concrete layer.
Detroit has the worse of the lot.
