micheal_can
Geography?Why is there no station near Kingston?
Nearest town on the proposed route is Sharbot Lake, about 75 km away. If another route is chosen, then who knows.
"Lanes not trains!""AXE THE TRAX!"
Much more difficult to dampen noise, it would be quite loud (and arguably an eyesore) with its proximity to many properties.Lets say that the line through Peterborough is to be used. What is preventing the consortium from raising it up high enough so that the level crossings are gone, and the bridge is high enough to clear boats?
It will without doubt be bypassed. A Peterborough stop can only generate so many trips. Let’s not ignore the fact Montreal and Toronto have 20 and 30 times greater population, respectively. Peterborough will grow rapidly when this train is in service but early days will see many trains bypassing their stop.The curve within the city could be near a station which would negate the speed limit. All of this would assume the station won't be bypassed.
I’m no rail expert, I respect there are many factors in determining max speed through a curve. Suffice to say, the curve in downtown Peterborough could not be traversed at even 150km/h – even on a new elevated guideway built for speed.Even if it is bypassed, what speed would that existing curve handle?
Because the new HST line doesn't go anywhere near Kingston. The closest the new line will get to Kingston is Sharbot Lake or Perth.Why is there no station near Kingston?
What this project needs is connections to non high speed rail travel methods at Peterborough to make it useful.I’ve been wondering how many trips would even stop in Peterborough. Barcelona-Madrid for example, a very popular HSR route, is largely express with only a fraction of the stops in Zaragoza, which falls right on the high speed. Get the network running between Ottawa and Toronto with some token park n’ ride stop in Peterborough to make all parties happy. If Peterborough wants a downtown station in twenty or thirty years, maybe it’ll sync with Metrolinx’ plans and there will be some shared wins.
The existing line through the city goes just south of the downturn core.What this project needs is connections to non high speed rail travel methods at Peterborough to make it useful.
Without that you will need huge parking lot.
Downtown Peterborough doesn't have a rail line anyway and downtown is built up so there is no way to get HSR there.
Look at a map of Peterborough. There is virtually no track left in the city, save for the CP line which crosses through on a roughly east-west axis.I'm not sure what you mean about trackage to facilitate a connection. Presumably a bypass would be built south of the city and connect to existing tracks at both ends. I'm this scenario the tracks going through downtown would have to be upgraded but would remain conventional tracks with grade crossings.
Because that is how you get scope creep and project failure. There's not much of an advantage for HSR to Kingston residents if they have to drive 50+ km away. That driving time cancels any savings from local VIA service. Meanwhile, it also slows down the whole line make it less attractive to all other customers.Why is there no station near Kingston?
I'm very familiar with Peterborough. Why do you say that a new alignment would be needed? The small number of trains that would use a downtown station would just use a rebuilt CP corridor. This is what Via pitched with the original HFR plan.Look at a map of Peterborough. There is virtually no track left in the city, save for the CP line which crosses through on a roughly east-west axis.
Assuming that the new high speed corridor is built to the south of the city, it would many new kilometers of additional new track and alignment in order to build a station close to downtown. Even if it's built to the north, the same thing applies. Thus building a connection to directly serve the city is going to increase costs substantially.
Yes and this is exactly what I'm suggesting could potentially be done with Peterborough.Now if you look at the high speed lines built in France, Spain or Germany you'll see that the lines also bypass the smaller centres, but have junctions with existing lines to allow trains to depart the high speed lines, travel on the old lines and reach the old stations located in the city centres. They then take those old lines to other junctions that have been built with the high speed lines, allowing the trains to rejoin those corridors.
