badc0ffee
Active Member
I'm not sure the green line part of this works as you'd need to go under the new-ish 4 St SE underpass, and I'm not sure the red line tunnel is deep enough.
I think a parallel bridge would be needed over the 4th street underpass. Then the train would have to descend to meet up with the Red-line tunnel. I don't know how deep the existing tunnel is, but there is about 180m of 'run-way' to make the descent. Not sure if that is enough.I'm not sure the green line part of this works as you'd need to go under the new-ish 4 St SE underpass, and I'm not sure the red line tunnel is deep enough.
Yes. It could be used.
IMHO the downtown alignment seemed pretty ill thought out. The underground section was way too ambitious...especially when low-floor LRT was to be the preferred technology. It's my understanding that rider capacity is limited on a low-floor LRT as passengers cannot stand on top of the wheel chassis.
To save costs and increase the efficacy of the project, I'd implement the following:
SE Leg:
1. Make the SE LRT a high-floor system. It runs in a dedicated ROW. There's no need to make it a low-floor system.
2. Fit-out the existing underground City Hall station shell and build the first section of the 8th ave subway to a station at Centre street. (450m of cut and cover along 8th Ave.)
3. Have a small section interlace with the red-line. (This kind of sucks because it hampers travel-time on the Red-line. Ideally red-line trains would be given priority until the entire 8th ave Subway is built)
4. Only rough-in stations at 26th ave, Milligan and 86th ave. to save cost and travel time. They can be built when ridership demand catches up.
NC Leg:
1. Utilize a low floor train. Have the entire NC-LRT run along Centre street. Low floor can be integrated into Centre street more easily than a high-floor system.
2.Built a Subway station between 6th and 7th ave.
3. Have the LRT surface north of 4th ave and have a surface station in Chinatown.
4. Utilize the Centre street bridge to save costs.
Forgive the terrible sketch I made during my lunch break...
Just the red line. The blue line would still run on 7 Ave. This increases track capacity for both lines.Does 8th ave subway means in future relocating existing 7th ave track to underground?
Not too crazy considering it was a studied alternative:Yes. It could be used.
SE Leg:
NC Leg:
View attachment 594852Is this proposal back on the table then??
Not a bad idea - do this above ground Green Line thing, but split the Red Line out with it's Stephen Ave subway project. For a similar length of tunnelling you get some total system improvements and a broader capacity bump, especially on the always-busy Red Line. I mean if we are going to spend $5B+ on some complicated big-city train system, this would be a really good upgrade.But IMO if you're building a subway under 8th ave you might as well just bury the Red Line instead and put the Green Line on 7th Ave, rather than kneecap the Red Line with the interline
It may be possible but I think the concept of an independent NCLRT coming into DT on the Centre Street Bridge is relatively new and probably only looked at a high-level. The previous designs using Centre Street would go west around 3rd Ave in order to eventually link with the SELRT. There likely isn't enough information to determine how south it can reach yet.In this scenario, could the NC line go all the way to Calgary Tower and then somehow punch through an underground or elevated and covered pedestrian pathway from a Calgary Tower NC line station to a Green Line station on 10 Ave and Centre Street? Not ideal but I recall making quite a lengthy connection between lines in NYC via an underground pedestrian pathway. Just my two cents worth and I have no engineering background so feel free to give any feedback you wish!
Well if the SE isn't going to connect, it doesn't really need to be LRT either does it?
As I'd mentioned a few weeks back, I suspect the dedicated ROW BRT plan would service the SE just fine for a generation or so. Plus it would have the advantage of also being a bicycle freeway, as well as providing unimpeded emergency vehicle access to the SE hospital if needed.
Should be the other way around IMO. Start with BRT for SE, build LRT for NC, then extend LRT to the SE as phase 3.
Yes, in an ideal world it would be connected and grade-separated. But the significant costs over-run have already compromised the Green Line:Ridership is one piece of the puzzle (and I suspect new modelling might show some minor differences with post-covid shifts out of downtown cores), but there are also a ton of operational considerations with disconnected lines. Then you end up with the need for a minimum of two facilities to maintain, wash, store trains and no real ability to get trains between the two segments in peak demand periods (e.g. a hockey game lets out, lets increase the number of trains in the south segment).
I'm not claiming to be a transit expert by any means, but every time you add a connection or mode change there has to be some expectation of ridership drop. If you make transit faster or more convenient, people may actually see it as a viable alternative which it rarely is today in our city.
What?! Is this you or Matt Jones saying this?elevated 7th ave alignment
