Thanks for your constructive criticism guys. It's not even my map but I find that vaguely insulting. It's one thing to point out things you disagree with in a constructive manner. It's very much another to dismiss someone's hard work as "silly". Unless you're saying it in jest, but somehow I doubt that's the case.
Alright, be ready for the constructive criticism now. Where to start...
The Yonge North... ICTS?! Yeah... stop Yonge at Finch, just to continue it with a slightly lower capacity service that still requires a grade separated ROW? Very, very bad idea. I don't get how people constantly deny that Yonge north of Finch is subway-level. As son as the DRL starts getting built, Yonge should be started up to Langstaff. It'll be needed to give a transit backbone through Thornhill, as well as transit-oriented redevelopment that's slated for the Yonge corridor. In my opinion, the Yonge subway could eventually go up to Major Mac to serve more density through RHC that could definitely be supported through redevelopment. I'd also add in the stations between York Mills and Lawrence, and Lawrence and Eglinton.
I'm fine with Sheppard East (though I'd add in a station at Progress to anchor STC development and a Progress-Malvern LRT.) But Sheppard West definitely has to go to Downsview. It has to exist to connect Yonge with the Spadina Line, which includes with VCC, York U, and Downsview. A stupid little loop to Senlac would be pretty useless.
A Finch Hydro Corridor RT should be regional, not as a local Finch LRT replacement. That'd be like Yonge, Bathurst, York U, Jane, Finch/Weston, then following the Hydro Corridor down to the airport. In the east, it could be Yonge, Seneca, Warden, McCowan, then down to Malvern and Pickering along the 401. A local TC-like RT would be needed to serve the rest of Finch, but probably well after at least a decade of ridership growth and more of the Finch-esque high density development.
I still don't understand the obsession over merging the DRL into Eglinton. Eglinton should be one line along the entire stretch. The very erratic DRL route would probably be immensely expensive, slow down the trains, and to be honest, there's a lot more high density development potential along the waterfront than in the old, stable neighborhoods that would probably just mostly serve a tourist purpose.
I personally disagree with the idea of the DRL west going north of Bloor. It'd almost exclusively follow the Georgetown corridor, and there's really nothing that demands a local stop spacing along that corridor. And instead of following the Georgetown corridor at all, I'd put it along the waterfront to the Ex, up to Parkdale and up Roncesvales. This'd provide a pretty easy connection with Parkdale and Humber Bay, spurring new transit-oriented development in both.
The subway north on Don Mills is a winner for me though. It's a wide road, so a raised guideway wouldn't be very bad, and would cut costs considerably on a route that already has density to support a RT, not to mention redevelopment potential. But I don't get why you put it back on the 404, instead of going up through the Peanut to Seneca. Since I feel like being picky with it, here's a section by section of the way I'd build the route north of York Mills:
After about Duncan Mill road, start moving the guideway down, probably expropriating some land to keep the lanes on the road. By the time it gets to the 401, it should be level with the ground. Then, right over the 401, there should be a ground-level station complex with connections to either side of the road, which would host a greatly increased sidewalk with higher barriers and maybe some greenage. This might be the only highway overpass that would work with rapid transit, because Don Mills doesn't actually turn onto the 401 so there's no danger for pedestrians with fast-moving cars. After the 401, it'd go underground quickly, to avoid expropriation needed on the more tightly packed section of the road north of the 401. After a connection at Sheppard, and stations at the north and south of the Peanut plaza, there'd be a station right at Don Mills and Finch, where the line would turn towards the main complex of Seneca college, with a station on the Hydro Corridor to make it easier for students, and as a connection with a FHC RT.
I don't get the Eglinton extension down under Pearson, but I can live with Eglinton east, even if East of Don Mills shouldn't come for at least 10 years after the original line's built. The current way things are going, I don't think that Jane needs a subway. Of course, that could change with new demand and such, but I think with a northern anchor (Spadina Subway) and an easy place to terminate a street-level RT (Eglinton,) it should do quite well with BRT or LRT.
I still like the 27 RT idea, but I think it'd integrate quite badly with the other routes you have there. There's really no demand for a route that creates a full circle around the city, but I'd definitely support a RT that goes from Long Branch, to Sherway, to ECC, to Pearson, then to Woodbine and maybe Humber College.
Yep, there's my constructive criticism.
EDIT: Whoa, what? I didn't realize this was in the Eglinton Crosstown thread. It's kinda off-topic now
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I thought that with the map and all, I was in the Fantasy map thread! Mods, feel free to move this post as needed.
Though you could keep this, I don't agree that Eglinton should be split up and some parts merged with a DRL. The Georgetown line would go very, very close to the Airport (the real reason for extending the DRL up there,) and the ARL would fill up current demand for a downtown-Pearson link. The Georgetown line should probably be rerouted under Pearson in the future, and that would totally kill any demand for such a route. Splitting up Eglinton to fit it with the DRL also takes out a 1-ride midtown link to the airport, and that transfer is drastically intensified when you're carrying baggage. I'm not saying that people won't take the subway to the airport, I'm sure that it'll see plenty of new transit riders. But that single ride is important, at least for customer satisfaction.
