vegeta_skyline
What else could it be, the doorway to Heaven?
Had you not said anything, I would not have known that is an exit sign...
Take note then for the next time you leave North America as you will find that sign or something pretty close to it in many other places. It already seems to be the defacto-standard.
It's interesting that they want you to run to the exit, instead of walking.
For one, emergency exits are usually depicted with red in North America, not green.
Some places in North America require green instead of red for emergency exit signs, Maryland for one. Green is actually superior because green means go, and lit green is more visible in smokey conditions than lit red is.
It still varies from place to place. In England for example, they've solved the lack of clarity on what the sign is for by adding a few words:
If a picture is unclear and cannot be understood without text, then the picture is pointless. If that picture is supposed to depict a fire exit, then I expect to see some fire somewhere. Show the guy engulfed in flames or something. Otherwise, just get rid of the stupid pictures altogether.
Reading Phantom27's links, it looks like this sign is NOT an emergency exit sign, it's an exit sign. As such, it's reasonable enough, although I do think that supplying text along with the pictogram would be superior.
Is there a separate emergency exit pictogram, perhaps with a fire, then?
