AnarchoSocialist
Active Member
2013 for tunneling according to the public schedules. Likely will have alternative project delivery however so no real certainty but the end date.
Your right. The new website does say 2013. According to this staff report it looks like Train won't be a separate project anymore. In fact it states that once construction at stations starts and bus service is removed it will not return. It also gives a slight overview of how they plan to divert bus services during construction time which is interesting to see (and going to be a challenge while it is in place).
Edit: This recent article from the Ottawa Citizen talks about the NCC re-examining plans for a Ottawa-Gatineau LRT loop. Nothing too exciting but Alex Cullen does make a good point that with the Ottawa LRT project in the planning stages the NCC may be interested in taking advantage of the timing and integrating it into their plans. It says a report will be issued next month. Will be curious to see what happens.
There is actually an official Interprovincial Transit Strategy website up now. It doesn't have many details about plans only saying that a report will be released May 2010. There general mandate is to find better ways of integrating transit in the region, mostly in the downtown areas, so aside from a potential loop project this would also be the group that would look at issues such as STO buses on Rideau and Wellington, using the Prince of Wales bridge for rail, and other transit issues.
While I am at it here a few other links that some might find interesting. There are other Transitway projects underway but these are the ones that are directly related to LRT expansion (not the first phase but central for the wave of extensions once the downtown section is done).
West Transitway Connection EA: This would complete the missing link between Pinecrest and the North-South Transitway that heads to Baseline. The Pinecrest to Bayshore section was recently open so this is really the last project that would make conversion of the Transitway to LRT from Lincoln Fields to Bayshore relatively quick and painless.
West Transitway Extension EA: This would add the missing section between Bayshore and Kanata Centrum. There is an initial report available on the Bayshore to Moodie Drive section available here. This is another project meant to make quick expansion of the LRT network possible by doing all the construction required aside from actually laying tracks.
Baseline Station: Here is a wiki link since I can't find an official update page for the project. The site also has a new Algonquin College building going and more is being planned so it is an area that should see a lot of change in the coming years.
Western Corridor (Tunneys Pasture to Baseline Station and Carling Avenue) LRT EA: This EA is odd because it looks at both the Transitway LRT line and a Carling LRT line. I am not sure if they are supposed to be considered separate or as equal alternatives to LRT in the western part of the city. Aside from the LRT line on Carling the two options considered are a parkway route and a Richmond/Byron route. Since the NCC has nixed the parkway idea, that just leaves one option. No dates for public consultations and open houses have been set yet but I suspect that will change by the end of the summer.
Plans for the current O-Train line are not exactly clear. The new Bayview Station design is clearly designed to allow for a connection from the North-South line. And the new website says the existing line will converted from diesel to electric during phase one of increment two of the Transportation Master Plan. Whether it will be converted so it can open alongside the rest of the LRT line or will start once the line is open I am not sure since I have yet to find anything that identifies a clear timeline.
Last Edit (Seriously...maybe): I came across a few more interesting things. First is the original North-South EA from 2004 which also included the surface rail portion through downtown (this was the project that was killed off by Mayor O'Brien. I have posted this because as far as I can tell most of the North-South line from Bayview to Riverside is still planned and it seems that much of this EA is still applicable when the time comes to build this section (though I am going to send off an email to confirm this for sure).
Below is a picture of Phase One of the LRT plan (click here or the picture for a high resolution PDF version). And here is the link for Phase 2 which is not that much different in terms of LRT other than a spur to the airport and LRT on Carling. At this point I suspect Phase 2 is likely to change (the airport spur will be built but I am guessing LRT to Kanata will come before LRT on Carling).
![](http://www.ottawa.ca/city_hall/master_plans/tmp/maps/index_en-7.jpg)
Phase 1 (as of the 2008 Transportation Master Plan) will be done in three increments. The first is the downtown portion (Tunneys to Blair and includes the transit tunnel through downtown). The second will see the LRT line from Baywview to South Keys converted to a twinned, electrified LRT line and extension from Tunneys to Baseline. The third would see the North-South line extended from South Keys to Riverside Town Center. Of course these are likely to change but this is the current timeline the city is working with.
It is easy to see how priorities have changed even in just a few years. The Pinecrest - Lincoln Fields Transitway link was not planned until Phase 2 but it is already being pushed forward as an important project. Likewise North-South line extensions into Barrhaven have been dropped.
