kEiThZ
Superstar
This also proves that the province and the feds will fund an alternative to a cancelled project as long as the municipality in question foots the bill for the cancellation.
This is fantastic news for an amazing project. I'm really looking forward to this getting started. As a former Albert Street resident, I'm thrilled that the endless bus parade will finally be replaced with something much faster and more reliable.
I think it's quite certain that this will be on a case-by-case basis!This also proves that the province and the feds will fund an alternative to a cancelled project as long as the municipality in question foots the bill for the cancellation.
And given we've been talking about this tunnel now for near 30 years ... I'm really not sure I'll believe it until they start digging the shafts.
I'm no expert on Ottawa's doings and transit plans, but what are the plans with the O-Train? I feel like if Ottawa will be LRT-izing their BRT network, would it make sense to turn the O-Train into a real LRT that is compatible with the rest of the network? With just a bit of extra money in tunneling through downtown, they could have a real strong network by integrating regional trains in with their LRT service. The O-Train should also be extended up across the Ottawa river through Gatineau, though assuming it has a somehow improved service.
Maybe if they replace the O-Train with LRT, they could send those DMUs over our way and test them out running in the Go system. That'll be the day![]()
What do you think? Should Ottawa cancel the LRT and push for subway? Or should they forget the tunnel, close off one of those 2 streets, and just run it on the surface.
The project as it is currently proposed is pretty much perfect for the city. It shouldn't be scaled back (nothing at grade, period, and certainly not running on streets downtown). Nor does it need to be expanded by turning it into a subway. Though the downtown section will be tunnelled, and sections between Tunneys and Lincoln Fields will be tunnelled or trenched, LRT is the best technology for the line. Basically Phase 1 (which starts with the tunnel and the line from Blair to Tunneys and then includes the N-S O-Train conversion and small extension and then Tunneys to Lincoln Fields) will be just right for creating LRT support and a backbone for the system. The downtown tunnel has also been designed so that eventual LRT lines out to Kanata in the west, a possible Montreal Road line in the East, and a Carling line, can all feed into the downtown line and not push the tunnel to capacity.
Regarding Rapibus: It is actually a smart choice for Gatineau. Like the Transitway in Ottawa it will help grow transit usage and serve suburban areas well until it makes more sense to build an LRT line (at least a line that follows the RapiBus corridor....a federal zone loop would largely be an NCC project). Of note, though the RapiBus transitway will be built largely in the rail corridor this does not affect the rail line. The current single track line will remain (though moved in some sections), and it can still be twinned in the future.
Won't the LRT upgrades basically be replacing current parts of the transitway, then tunneling through downtown? If that's the case, it'll be 100% grade separated anyways, won't it?
I think that if they're converting the O-Train so it can be compatible with the rest of the LRT network, the O-Train should go through Gatineau and create an integrated transit network throughout the entire capital region. It'd make a lot more sense to do that across the rail corridor now, and then add BRTs branching off from the O-Train.
^ Phase 1 is going to Tunney's Pasture. There will be an overlap in service between buses and the LRT. Buses will end service at Bayview. LRT will end at Tunney's. It's the tunnel that ends just before LeBreton.
