If Eglinton is to be elevated through Scarborough, it must also go over the DVP. I also thought it would be nice to keep the Leslie Station, or at least keep the option open for when (if) the CPR line gets GO service.
So this is what I am thinking.
1. Just east of Laird Station, the line needs to continue roughly horizontally, instead of diving to go below the Don River West Branch.
2. At about 943 Eglinton Avenue East, the TBM launch site will be built. The ramps to this property may need to be closed, either temporarily or permanently, but access can also be obtained from Vanderhoof Avenue to the South. The horizontal alignment would remain roughly horizontal, maybe a slight shift in plan away from Eglinton. This would also become the Portal location where the line switches to being at grade.
3. The line would stay roughly horizontal and then slope down at-grade along the valley slope. The line would cross the Don River West Branch on a separate bridge – the height above water probably a bit higher than the road bridge.
4. A new semi-outdoor, at-grade (partially elevated) station can be located at Leslie. This may be optional at this time. It would also serve a future GO station along the adjacent CPR line.
5. The line cuts through the CPR embankment using twin tunnels, constructed using jack and bore. The line is rising, following the grade of Eglinton.
6. To keep the line closer to Eglinton, the ramps to Celestica are reconfigured to a Diamond interchange – eliminating the loop ramp. A left turn would be needed to go under, or come from under, the bridge. The horizontal alignment would have to be moved marginally farther away from Eglinton.
7. About 300m west of Don Mills, the line enters a portal and the entire area is built using cut-and-cover. Cross over tracks can easily be located in this area.
8. The Don Mills station is redesigned completely. First, both Eglinton and DRL are single platform. Next, the Stations are shifted to the South and West and the bus station is also switched to this corner. The mezzanine level is directly at grade, located between 0 and 4m below ground. The ECLRT is located about 5m to 11m below grade, while the DRL is located about 12 to 19m below grade. Since the station is not under the roadway, this mezzanine will not interfere with utilities under Eglinton or Don Mills. There are pedestrian tunnels under both Don Mills and Eglinton. The DRL is accessed by elevator/stairs in the mezzanine near the bus station, and also from the pedestrian tunnels, both south and north of the platform. The ECLRT platform is accessed from the same mezzanine, and also from below from a deeper tunnel under Eglinton and under the ECLRT platform. The goal is to reduce the depth of the station to have less of a climb to go over DVP.
9. The line rises at 4.5% after passing the station. The portal would be located about 200m east of the station. The Gervais Drive intersection would have to be move about 25m closer to Don Mills. The line would be immediately to the south side of Eglinton.
10. For about 200m, the line runs parallel to Ferrand Drive. The line continues to climb at 4.5%. In this area, the line has left the portal and is below grade, at grade, and above grade, but not high enough to pass under it. Just before the DVP on ramp, the elevation of the line is adequate for the ramp to pass under this elevated portion. Eglinton Avenue may have to be shifted marginally to the north (instead of widening on both sides if a median portal was used), or Ferrand could be switched to a one-way road.
11. Don Mills starts to slope down, but the line must continue to rise to go over the DVP.
