WislaHD
Superstar
Yup, probably because they've been busy with the side streets up until last Friday when they started working on Eglinton.
That is what I thought too, but (and someone correct me if I am wrong) it appears that the platform 70m north of the current platform was built alongside the original platform, and will boast the current platform width as today. As far as I know there are no plans to rebuild it wider, though I think there should be. (As I expect Eglinton will have more ridership than anticipated)
They aren't. It will still be a single centre-platform. They can't make it any wider without moving one of the tracks - and that's not planned.The entire Yonge line platform at Eglinton is going to be rebuilt 70 m north of where it is now to accommodate the LRT properly, without stairs being available only at one end of the platform (causing a choke point)
I imagine they will rebuild the platform (like with Union station) to create wider platforms.
They need to find a way to make it practical. Stagger the platforms maybe. It's not impossible ... just a lot more $$$.Unfortunately, making the platform wider would require moving the tunnels to each side, not only for the length of the new north part of the platform, but also for the part of the existing platform that would remain and for the approaches on either end, which is not practical.
Even after this, Eglinton platform will still be as crowded. Just will be different location. Moving platform may help it not get as worse as it would get otherwise - but doesn't make it any less crowded than today.
But they otherwise, they are setting themselves up for another Bloor-Yonge problem.
So basically your saying they should spend tens of billiions in modifying the entire subway line, rather than spending an extra half-billion on the station ... :facepalm:Instead of making the platform wider, they could make it longer to fit 7 or 8 car trains. This is needed only at the major stations on the line - at all others, the front and/or last cars from each train would not line up at the platform and would not have doors open.
One there demand at Eglinton West is lower. Two is that there are already 2 platforms on Line 1, compared to 1 at Eglinton.Interesting that the off-centre interchange will be fixed for Eglinton/Yonge, but it will be left in-tact for Eglinton West, where there is a 75m walk down a corridor that is immediately adjacent to the subway tunnel
It says exactly what I thought it said.Maybe you could read before posting.
Ahahaahahahahaha. Haahaha.
Ha.
That's funny.
What were these guys smoking when they came up with those numbers? I want some of it
not for a long time, if ever. its not on any priority lists for funding and from my understanding doesn't have a particularly good cost benefit ratio. Its essentially dead along with the other transit city lines that didn't receive funding.
