JWBF
The title "thoroughfare" comes to mind.Pretty much a local road, although wider than many other local roads.
There was "talk" about a multi-level parking garage over the Allen Road, north of Eglinton. Never happened. (Unless we consider the Yorkdale parking garage as a descendant of such "talk".)
I am all up for the idea of filling in the Allen.
"revenue tool" I will call it.
Actually the allen is faster. My wife and I use it daily. At least it's better than dufferin.During rush hour, Allen Road is no faster than parallel roads, such as Avenue Road or Bathurst Street. In fact, its often slower than the latter two roads.
...and has local bus service as well with Route 109 RaneePretty much a local road, although wider than many other local roads.
I don't drive there very often; a few times I did, northbound Allen was pretty fast and not congested. Definitely faster than Dufferin or Bathurst.
Southbound, the fastest option is probably taking Allen to Lawrence, then exiting at Lawrence and bypassing the Eglinton & Allen intersection (that one is always filled, even off-peak and was so even before the LRT construction started).
Yes, but it would take much longer to use those parallel roads if the Allen was closed, since all the current traffic on the Allen would be forced to those streets??During rush hour, Allen Road is no faster than parallel roads, such as Avenue Road or Bathurst Street. In fact, its often slower than the latter two roads.
Also, who uses the same road everyday in the age of Waze.
and difficult to cross Marlee on foot or by car at intersections because there are no stops signs or stop lights till you get to Glencarin or maybe Glen ParkPretty much a local road, although wider than many other local roads.
I'm curious, where have we seen that in Toronto in the past?I suspect it would be slower, but it's hard to say with induced demand being a factor. As we've seen in the past, freeway removals often cause the demand to evaporate, with nominal impact on travel times.
I'm not convinced that Allen Road has had a significant benefit to commutes, beyond making it possible to fit more cars on the road (and its questionable if thats truly a benefit).
Indeed. Toronto is a relic in many respects:I was talking about other cities. Toronto has only had one past freeway removal (Gardiner east of DVP), but few people used it in the first place so it’s a poor example.
