elcorrerador
Active Member
I don't want to derail the thread but is there any news about more grocery stores coming in the area?
I thought I had seen Farmboy mentioned in one of the other threads.
interchange42
Administrator
Staff member
City:
Toronto
evandyk
There was also some talk about a grocery store opening in the Power building at Adelaide and Power, but I'm not sure if that will happen now. There is a smaller grocery store opening in Canary on Front St.
There is also hoarding for an Italian store in the Daniels building, but that predates the pandemic, so I'm pretty skeptical that will happen.
Northern Light
Superstar
From the Report above:
Summary of changes from original proposal:
S. 37 benefits:
As part of the Transportation Demand Management program:
Final Report https://www.toronto.ca/legdocs/mmis/2022/te/bgrd/backgroundfile-227520.pdf
Not clear if the No Frills is going to be continuing but it is mentioned.
The Loading standards are revelatory:
Loading
Three Type B and three Type C loading spaces are proposed. One Type C and all three
Type B spaces would be provided within a consolidated at-grade loading area at the
west end of the site, accessed via a vehicle turntable. In addition, two Type C loading
spaces are provided on the P1 parking level, one beneath each of the new buildings.
Notably, a Type A loading space is not provided, as it was determined that the
reconfigured ground floor retail space will result in the loss or downsizing of the existing
grocery store use, for which the loading needs could be met using the smaller Type B
spaces provided. In addition
, a Type G space is not provided, as the proposed location
of the site’s consolidated loading area within the existing Northwest Office Building does
not provide the necessary vertical clearance. As such, private waste collection is
proposed to serve residential needs.
dusk
Active Member
S. 37 benefits:
Loading
I do worry about the future of the No Frills here. Are there no frills in the city that occupy a space 50% plus or minus of the current location? I'm not aware of any.
I am concerned that an "upscale" grocery store will enter the space and squeeze residents, many of which rely on the relative affordability of the No Frills.
Jonny5
50% larger for sure with the Dufferin Mall store which is huge. Some of the ones on the edge of the inner/outer suburbs are like that too. I'm not sure about 50% smaller, but the Parliament store is definitely smaller, but probably only about 15%-20% or so.
Northern Light
Superstar
A fair few actually.
The Parliament Street store, I think, is the smallest No Frills in the City, at ~13,500ft2
The one on Bloor West (just west of /High Park) is under 15,000ft2
The very first No Frills is still operating at Victoria Park and St.Clair and is well under 15,000ft2
The existing store is well over 30,000ft2, so all of the above are well below 50% of the current footprint.
dusk
Active Member
Thank you for the info! That’s helpful :)
jsmith77
Active Member
All makes perfect sense I suppose, building affordable housing on two large sites within 500m or so, then cut access to affordable groceries. Crazy to think of how long the lines are at No Frills at its current size and how much worse that will get with increased population and smaller footprint.
elcorrerador
Active Member
It's very bad. They also don't have self checkout machines there. They should because lots of people go to grab a couple of things after work.
Rush hour is the worst time to go
