ShonTron
Moderator
Rob Ford did say he was going to stop the Gravy Train. It's just that the Gravy Train will be stopping at Victoria Park, Warden, Kennedy, Midland and Scarborough Centre.
For new development on Sheppard the TTC can be awarded land for free and developers would forever have to pay the lease to the TTC but are free to build what they want on the land itself.
Asking the province for money to build the Sheppard Subway extension, is the same as asking for taxpayers' money. It's the same pocket.
This from a mayor who avoids pubic transit, does not know the difference between a streetcar and a light rail vehicle, and needs an automobile to get a Timbit instead of walking to a library.
Um, there IS no difference between a streetcar and an LRV. Not really.
There is a difference between streetcar routes and LRT routes though.
Ford can get roughly $3B in Sheppard funding tomorrow by announcing Eglinton's Eastern component will be above ground as per the original plan.
Yeah, this is the most amazing part of the story. He has publicly made the Sheppard extension one of his top priorities; his plan is obviously faling apart; and he has an equally obvious fix at hand, which can give him two new transit lines instead of one for the same cost. Yet, he won't budge.
Being both incompetent and stubborn is a lot worse than being just incompetent. Too bad, three more years before we can actually have a transit policy.
I'd be pissed if Eglinton was placed above-ground, and so would the rest of the constituents on Eglinton. They don't want an elevated subway in-front or behind their house.
Would you support an above-ground line if it meant that it could be longer or that some of the money saved could go to Sheppard?
Im ok with Eglinton being built elevated after Vic park and after Jane to the airport. However if Eglinton goes elevated then it should be contingent on the Sheppard Subway being converted to LRT and then run elevated as well. If elevated becomes the solution it should be implimented in both situations. And it also is rediculous that Eglinton have to cut back its spending to subsidize a SUBWAY system which we all know if under served and will continue to be underserved... Elevated could also be a solution to the Jane LRT situation south of Eglinton where the street is to narrow for in median service.. This too is the situation from Bloor to Eglinton on the don mills side. How about a JANE and Don Mills LRT that goes Elevated at each section from Eglinton south and connect with eachother through the downtown core somewhere. A One way street like richmond or addelaide would be perfect for this. I know its not a perfect DRL but its a far cheaper one...
I doubt you will ever see an elevated transit line in the downtown core. A lot of political capital has been invested in the "tear down the gardiner because it cuts the city" argument for people to turn around and say "build another physical barrier so we can run a LRT on it"
The gardiner is becoming less and less of a barrier with the condos closing around it... In fact I think alot of torontonians are beinginning to realize that even if the gardiner disappeared the condos will still own the water front. Also a elevated LRT line would be the equivelant of two lines of traffic above any given street. That is not at all comparible to the gardiner which is 6 lanes wide or the rail tracks which isabout 4 lanes wide.. An elevated LRT line would barely cause any disturbance especially on one way streets wihtout much pedestrian traffic such as richmond.
The GO transit lines are elevated through downtown from about Simcoe to Cherry.I doubt you will ever see an elevated transit line in the downtown core.
