digi
Active Member
How much problems does the TTC have with those sneaking thru turnstiles or illegally entering a bus or streetcar at a rear door?
Lots of problems, they actually encourage it on the 501.
I guess this is slightly balanced out by dopes like me, who - when I don't have tokens on me -- end up paying $3 a fare because, seriously, who carries quarters on them any more?
Lesouris's explanation isn't exactly right. After all, Royal York and Islington stations were built at the same time beyond the fare boundary and have fare-paid bus terminals, while Runnymede isn't fare-paid and was inside the boundary.
It has to do with the design of the station. The way they built it there is no room for a fare barrier on the ground level, and people access the station through the bus terminal.
So, the question is: why didn't the TTC expropriate more property in Bloor West Village for full-size stations with bus terminals when they built the subway? Politics or something else?
If the TTC required riders to swipe in and out at different stations or when getting on and off the bus there would essentially be a second barrier in place.. also a more advanced fare calculation system could be introduced charging less for short trips and a bit more for long trips as well as eliminating the need for paper transfers.
I've often thought that a turnstile at the door on the buses that opened once the fare was paid was the obvious solution to fare jumpers, plus it removed the driver from fare collecting. Of course you'd have people with huge strollers, walkers and bundle buggies complaining about access.If the TTC required riders to swipe in and out at different stations or when getting on and off the bus there would essentially be a second barrier in place..
I disagree.
Since the area inside the subway fare barrier was in Zone 1, but the stations’ bus terminals were in Zone 2, the bus terminal had to be outside the barrier in each station. (At the boundary stations, Jane and Main Street, Zone 2 buses and Zone 1 buses or streetcars came together. Rather than the complexity of separate terminals, a single terminal outside of the station’s fare-paid zone was used in each case.) At Royal York and at Main Street stations, the fare booths were placed on the mezzanine level between the bus terminal and the subway platforms. When the zone fare system was eliminated, the TTC moved these fare booths into the bus terminal, between the main entrance and the westernmost bus bay doors. This is why the mezzanine levels of Royal York and Main Street stations are especially long.
Islington had more difficulty in expanding its fare paid zone to include its bus terminals, primarily because the TTC did not want to move the collector booths from their original location. The fare barriers were forced to meander in order to separate passengers entering from the street exits from the bus terminals. This was solved when the entire fare area was reconfigured and the collector booths moved during renovations in 1996. In the case of Old Mill station, buses turned around right outside the main entrance to the station, making the expansion of the fare zone to cover the bus stop impossible. A similar problem occurred at Jane station, with the bus terminal and the street entrance being too close to each other to easily separate. To the east, Victoria Park and Warden stations were quickly converted to include their bus terminals in their fare paid zones.
I have no idea why Runnymede's bus bays weren't built into the fare-paid area. Was the station served by any fare zone 2 bus routes when it opened? That might explain it.
Speaking from experience, many of the metro stations in HK also have large bus/LRT terminals above/below/next to them, so they are certainly not unique to TTC. The difference being that those buses aren't operated by the same company as the metro, so the bus bays are not in the fare-paid area. However, transfer is still seemless due to the use of smartcards, transfer discounts, etc, so bus ridership certainly isn't discouraged by the fact that the passengers have to swipe out and in.Busbays must be preserved, because they are what make the TTC's system unique. Buses are not seen as separate from subways, and this encourages bus ridership. A healthy transit system requires a healthy surface network, and getting rid of the busbays will create traffic jams on the surrounding streets (perhaps leading to calls to reduce bus service, which a pro-car city council will happily do).
Why do you say that?Besides, it is so easy to sneak into the subway that fare evasion will continue to exist regardless.
Enforcement is certainly necessary, but I personally feel there are much better and more efficient ways of dealing with fare evasion (along with a better fare structure, fare integration etc). It will, of course, cost money and effort, and as I asked earlier, had rigorous cost-benefit analyses ever been done? In any case, I think an honour system would be a backward step, but again, I am open to it if actual, rigorous studies show otherwise.The issue of fare evasion could be addressed (but never eliminated, no system will ever eliminate fare evasion) through surveillence cameras and actual enforcement of the rules, which is pitiful as it stands. In the future the system should be moved to an honour based system, though this will require actual investment by governments so that people will actually want to pay to use the system.
I fully understand if the person has little money and is desperate,say sneaks on a subway to get home but to me it is different if it is someone who has no money problems but evades fares to "screw" the system.
Rail you dont need the staff. I gave the example of NYC's metrocard, where its swiped at a turnstyle and the transfer is recorded on it. It either permits the rider through or charges a new fare, depending on the circumstance. It needs no new staffing what so ever, and the ATU113 will be against this along with any other automation
