TDE
New Member
This is one of the coach shop storage tracks. This track in particular is mainly for cars queued for repair.Is that an active consist or a storage line?
Odd. Wonder what could need repairing since afaik the car hasn't been used on any in service trains.This is one of the coach shop storage tracks. This track in particular is mainly for cars queued for repair.
Most of the MP40s seem to be fairly sooty nowadays.How often does Alstom clean the locomotives? The MP40's seem to generate a lot of soot/ residue from the exhaust. Leaves an unsightly streak that runs down the front of the locomotive. I'm assuming this is caused when the locomotives are pushing the train and the crew is in the cab car.
I've seen it get worst than the picture I provided.
It depends on the trainset's cycle - each train ends up at either Willowbrook or Whitby at worst every 3 days, and so they would get washed at that time.How often does Alstom clean the locomotives? The MP40's seem to generate a lot of soot/ residue from the exhaust. Leaves an unsightly streak that runs down the front of the locomotive. I'm assuming this is caused when the locomotives are pushing the train and the crew is in the cab car.
20 years...saying it like that was a bit of a shocker, I still think of them as 'new'!Speaking of, wonder if/when we'll see the MP40s receive refurbishment. The first 27 or so are approaching the 20 year mark soon, so I feel refurbishment may be on the way soon.
They're not looking to do any big wholesale rebuild such as what the TTC does. And it's been going on for quite some time now, although it's happening as units have major failures or are due for major servicing.Speaking of, wonder if/when we'll see the MP40s receive refurbishment. The first 27 or so are approaching the 20 year mark soon, so I feel refurbishment may be on the way soon.
Why would GO need fewer locomotives after GO expansion? Wouldn't they need more?I’ve heard that the engine fleet as a whole is much more unreliable than we might think, which is a possible reason why they’re tendering 50 new engines with the plans to replace a chunk of the existing fleet. If this is the case it explains a lot because GO won’t need 140 diesel engines after GO Expansion
I’m hearing reliability with the existing diesels is a massive issue too.I’ve heard that the engine fleet as a whole is much more unreliable than we might think, which is a possible reason why they’re tendering 50 new engines with the plans to replace a chunk of the existing fleet. If this is the case it explains a lot because GO won’t need 140 diesel engines after GO Expansion
They’re electrifying the network so they need fewer diesel locos as OP said.Why would GO need fewer locomotives after GO expansion? Wouldn't they need more?
Fewer by only a couple, the existing diesel fleet could stick around in its entirety as spares and to sustain the non-electrified parts of the network, but there’s definitely no need to expand the diesel fleet.I’m hearing reliability with the existing diesels is a massive issue too.
All I’ve heard is that the entire fleet is experiencing reliability issues, and there’s more out of service engines right now then what’s acceptable, not just the F59’s or the older engines.When we say “the existing diesels are unreliable” are the 710-DC ones the problem, or the newer QSK60-AC ones? Or is there a common issue in the control and/or electrical systems?
The 710s being a problem, you could write off as down to age or whatever. The Cummins stuff being off would be disastrous. But as the HSP46 and F125 showed, or even GO647, locomotives aren’t simple to make…
