 9.9K     0
 5.6K     0
After going through some photos I took last week, I noticed that GO 602 (one of the oldest MP40s) now has the same roof-mounted particulate filter that 657-666 were delivered with. Does anyone know if this was just a one off conversion, or is GO planning to retrofit other units?
I first noted the additional filter/muffler on 602 on March 13th of this year. 620 has also sported one since at least September of last year.
They need to develop single levels too. Not every system needs a giant bilevel or multilevel, esp in the lesser go lines (Rh, Niagara). Sometimes it's better to run more frequent smaller trains than giant ones that come infrequently
Very true and is nearly always the case in more suburban/RER type systems. Big double levels are fine for standard commuter rail where people get on but all get off at the same station ie Union. RER on the other hand will have vastly more people getting on/off at stations thru-out the system......…...basically it's a subway system with fewer stops but the riders have the same needs. This requires high de/acceleration electric trains and very importantly ones that offer fast boarding/entry which bi-levels most assuredly don't.
Is there an operations cost benefit to running single level cars rather than bilevel? Is the weight difference that big because the amount of additional air resistence seems pretty small.
The day of the DD being considered superior is passing. Some systems, like the Sydney and Paris RER where DD are run in tunnels are adding a third set of doors mid-coach to expedite dwell time in station. DD are now considered optimal for outer urban longer trip commutes. For RER though, single deck but 'unit-trains' like the TR subway trains carry just as many passengers as conventional DD, but have a much shorter dwell time and accelerate and brake faster due to lower weight per floor area to do it.
The claim is still controversial, but being accepted more, and can use a considerably smaller tunnel to do it.
Here's a very modern Class 717 running third rail (it's a hybrid that also runs on mainline 25kV) through tunnels smaller than TTC subway ones: (4.9m for Great Northern vs. 5.4m + for TTC)
https://www.youtube.com/results?search_query=class+717+great+northern
This is one of the reasons why Melbourne phased out it's double levels decades ago...……...they actually can have higher capacity and offer far faster travel times. While Paris runs DD on some of it's RER routes, the analogy with Toronto is not a valid one as Paris already has a huge Metro system for more local trips so people who use Paris RER are very much regional travellers.
DD are also notoriously bad for people in wheelchairs, the elderly, and strollers. People always congregate around the front doors when going shorter distances but those areas are the only ones accessible for people with mobility issues unlike single-level trains. With a fast aging population such concerns will become even more of an issue on suburban/RER systems. This issue doesn't really effect DD commuter rails as there is very little on/off boarding as people are travelling longer distances and hence are vastly more likely to take a seat than a RER system and getting off at a single point ie Union...........the entry areas are only used by people they were designed for, those with mobility issues.
Since Europe run train sets from 3-11 units that are Mu as 2-3 set doesn't mean GO can't do it as single level cars with next to no labour cost. GO can run a 2-3 pack set at peak time and cut one or two off for off peak since there very little extra idle time hocking them up or cutting them off at X point. There is extra capital cost. You could run a 3 set to either Aldershot or Hamilton where 1 set carries on to Niagara Falls and another to X. They hock up on the return trip to Toronto.
If GO did this like its done in Europe, don't need those accessibly platforms and better access to the cars for everyone. This style comes in different forms for both low or high floor from slide out to fold down. The gap plate for most cases are a lot closer to the platform than this example in Spain.
You must be confused on the city. Melbourne never had DDs. Sydney did and still does:
4D Train - Wikipedia
https://en.wikipedia.org/wiki/4D_Train
The 4D was a prototype double deck electric multiple unit built for the Public Transport Corporation, Victoria, Australia, for operation on the Melbourne railway system. It remains the only double deck train ever to have run in Melbourne.
Why does Melbourne not have double-decker train carriages as in ...
https://www.quora.com/Why-does-Melbourne-not-have-double-decker-train-carriages-a...
Aug 17, 2018 - Melbourne did consider introducing them. In fact, the tunnels in the City Loop are all double height, in anticipation of double-decker trains being introduced one
But here's why:
Melbourne did consider introducing them. In fact, the tunnels in the City Loop are all double height, in anticipation of double-decker trains being introduced one day, and such vehicles did trial runs on the Belgrave/Lilydale lines. There are two main reasons why Melbourne ultimately opted not to use them.
  1. Infrastructure. Most of our railway infrastructure was built for single-decker trains, and most lines had at least one point (be it a bridge that wouldn’t be able to withstand the extra weight, a level crossing without enough space for a double-decker train to pass through, etc.) that blocked double-decker trains from passing through. All of those points would have to be rebuilt in order to make the transition, which promised to be massively expensive.
  2. In many ways, double-decker trains are actually inferior to single-deck ones. Yes, they can carry more people, but because it takes much longer for passengers to reach the doors to get out at the end of the trip, trains are required to stop for longer at each station, and dwell times blow out. Many of Melbourne’s suburban lines are very long, and this could have seen a trip from Frankston into the CBD increase from just over one hour to almost two hours, for example. Double-decker trains work better for express services where few stops are made, but most lines in Melbourne lack the third track required to make that possible. (I mean, we still have sections of the suburban network which lack even a second track…)
Overall, it was deemed that introducing double-decker trains would slow down journey times unacceptably, and be too expensive to boot. Instead, governments have expanded the size of our single-deck fleet, stopped running three-carriage services (all three-carriage trains are now permanently coupled) and have (far too slowly, but still) responded to increasing passenger demand by running services at higher frequencies.
1.3k views · View 14 Upvoters
- : link above
Here's the 4D proto:
Melbourne did have DD like Sydney until the 1970s.
We only ever had a prototype - the 4D (a single 4-car set only) - and it kept on breaking down and had a very very patchy in-service history - starting off by operating as a standalone 4-car set initially and after so many breakdowns it had to be coupled with a 3-car Comeng.
I was hoping you'd catch that. The DD debate is still rabid in Oz, especially in Sydney with the new metro. There's an optimized case for both single and double, but single with lots of doors and walk through unit-trains is now considered best for intra-regional, and DD for inter-regional. This has a huge advantage when utilizing tunnels that would otherwise be considered 'subway bore size'.
Btw: When do we get the Summer you should be finished with by now? We're waiting...
It's pretty much only contained within Sydney - the DD/SD debate. And they just announced over the weekend that Sydney Metro phase 1 (the new single decker automated system) will begin ops on May 28th.
There's going to be argy bargy just after it opens, because the first phase dumps people out on the platforms at Chatswood (which already has packed trains which then head via North Sydney and over the Harbour bridge into the city), however the impact of that has been neutered somewhat because a few years ago the state government got ahead of it all and kicked off phase 2 (which already has TBMs chewing up the ground toward the harbour and city already). There's only going to be a few years of pain (transferring at Chatswood) before the rest of the new line continues under the harbour/through the city and out to the southwest).
The NSW Government also last year begun a programme very similar to the one the VIC gov has been pursuing with existing rail networks: moving to moving block / CBTC signalling (the Melbourne Metro project is bringing that to about 40-50km of existing and new tunnel track) and if I remember correctly, the first line to get that treatment will be the Illawarra (southern) / Eastern suburbs line which will see upgrades to rolling stock, but they'll still be DDs. Once both projects are done in either state it'll be interesting to compare throughputs - Sydney's 8 car DDs versus Melbourne's new 7-car SD "HCMTs".
The only way I see Victoria getting DDs in the future is potentially on regional routes. There's 3 major project moving parts to the west of the city at the moment that relate to a) finally building an airport rail link b) the state government's suburban rail loop proposal and c) extra trackage to fully separate metro and regional services to Geelong and Ballarat (Geelong and Ballarat are to Melbourne what Hamilton and Kitchener/Guelph are to Toronto respectively).
Consensus seems to be moving to another track pair from the centre of town, underground, and whether or not regional services use it, we don't know (they'd have to electrify at least one of the regional lines - probably Geelong - if regional services will use the new track pair) - but overall, the trend is to longer platforms and longer SD trains here, but I wouldn't completely rule out a sub-fleet of DDs as the next gen of 160-200kph regional trains (which is another aim of the state gov, moving regional trains to max speeds of ~200kph - building on the 160kph work that was done last decade).
Hopefully it will put a lot of endless debate on the matter to rest. Whenever I Google on the subject, Sydney always dominates the first ten hits or so
Is this the one that slices under the downtown loop (whoops..."CBD" loop)? I remember you giving me a heads-up on that months back. It seems Melbourne is also host to some abandoned tunnels down there IIRC.
Gotta tell you I'm really impressed with the 'leading state' of signalling and control as you describe. It compares to the best in Europe right now.
I'd bet the GO bilevels are some of the cheapest commuter cars on the continent to manufacture too simply due to scale.
Efficiency of scales. Hauling 1400(+) passengers at $x fare against paying 2 employees (driver and CSR). However all things being equal (same number of passengers in single and bi level cars) I don't know if there is much difference.
Drag from air resistance ramps up pretty quickly, I'm no expert but it goes up much more than you would think.
