By the way, that 57 million figure is way closer to the 49 million I eyeballed earlier in the thread. I knew 13 million seemed off. Not sure why the discrepancy.
I think the idea that GO will be carrying less than one million in 15 years is laughable but it will all come down to frequency & fares. It looks like ML is going provide service of every 8 minutes on core routes which will take it from suburban rail to a real rapid transit system. Of course it will mean little to Torontonians themselves if they still can't afford to take it.
IF they make the system affordable with complete integration then ridership will soar and probably overtake subway ridership in 20 years especially, if they go ahead with the Mid-town corridor. There are many systems in the world where suburban rail ridership blows subway ridership out of the water................... Paris, BA, Osaka, Tokyo, Calcutta, Mumbai, Sao Paulo just to name a few. It is especially true in cities with relatively small subway systems for their size. In Paris the RER & Translien suburban and commuter systems carry more than twice what their very heavily used Metro system does.
In 20 years the GGH will be home to 15 million and by 2050, GO could be carrying up to 2 million passengers a day if they do it right.
This is accurate. But am curious if a healthy (and possibly more successful) alternative to such high quality commuter rail is quantity. As in: more lines spread across the GTHA. Brantford, Bolton, North Brampton, North Oshawa, Cambridge. All areas not served by any "RER" plans, but all capable of intercepting riders and offering alternatives. Less quality than RER, more quantity of service.
Eventually RERification would still occur. But at a later date, when more GO rail services are brought online.
So I've been wondering this for a while now
It is to my knowledge that with GO Expansion the Stouffville and Kitchener lines will be fully interlined like the Lakeshore line, correct?
If that's the case, how would the Barrie Line work, as right now it is also semi aligned with the Stouffville line on weekdays and nearly fully aligned on the weekends. Would it operate as a stand alone line?
At this present time, its a stand alone line.
If and when the Milton line can become all day, it could be part of the Barrie Line, but not holding my breath on it.
At rush hours, that is incorrect. The only lines that will interline and run-through at Union will be the Lakeshore Lines, and even then it won't be all of the services on those lines. All of the others will turn back at Union.
They may run-through the services at off-peak times but that's dependent on a whole bunch of factors that, to the best of my knowledge, haven't been decided upon yet.
Doesn't that tie up valuable platform resources at Union with crews needing to walk the length of the train to drive the train back where it came from?
It has to happen at the end of the line regardless if its Union or Mount Pleasant or X. The amount of time that the train sits there is subject to its own line schedule; other interline schedule; as well how long it takes to off load/load. Then there is the in/out bound traffic that cross that track at Union as well other lines using the same track going the same direction of the train.
Yes, but it takes almost as long for a train to travel the length of the long platforms.
A single track has a throughput of 6 trains per hour if they all run through.
With "double berthing" - having two trains stop on the same track and reverse back out - they can get 8 trains per hour per track, 4 in each direction.
Do we not need even more throughput than you note above, for the GO RER service plans? (I'm hearing peak-headway of 5M as a goal)
I'm curious about the very short track 4th down from the top on the west end? Could they be moving UP from a dedicated station? I can't think of any other west end train in regular service that would be that short....
They have publicly stated that the plan for UP is to discontinue it and replace it with a regular service, including moving the station to Union proper.
Current UPX Union Station location is closer to SkyDome Rogers Centre. Longer walk if moved to Union proper.
Others have pointed out, Union is the more likely origin/destination of most UPX passengers.
As apart from that, replacing UPX with regular GO service, should it properly serve the airport, with mainline track, the potential exists for far greater convenience for passengers coming from the north-west, and for more frequent service, with greater capacity. No reason for sadness with this development.
