Yeah, I just meant of the three, the one that is on both the south and the east side. Basically it forms a square with St. Urbain bagels and Alex Farms cheese.
They are just putting the final touches to the paving of Wellington Street from Yonge to Church and are working on painting the pedestrian crosswalks. The intersection of Scott & Wellington remains temporary (and a mess!) until next spring and they look as though they will now turn to putting temporary asphalt on the south sidewalks from the west end of the Flat Iron to Yonge. The area of the sidewalk AT the Flat Iron may be getting the final bricks - but the frost may put a stop to that idea.
They promised to use a tent that the workers are able to put in the bricks.
Yes, the corner of Scott is a mess. The street lights are still covered with bags?
Yes the (short Victorian) lights remain bagged for some reason that I cannot understand. I assume THSL can keep working even when it's cold and the street needs to be properly lit so I assume (always a bad idea with THSL!!) that they will sort them out and install the proper LED tall fixtures too.
Wellington Construction Update
January 11, 2023
RE: Wellington Street E Fully REOPENED
Due to warmer weather conditions, road work on Wellington Street E has been completed. Our contractor is currently completing temporary sidewalk restoration work on the south side of Wellington Street E. All surface level road work has been completed as of January 10, 2023. Wellington Street E is now fully reopened.
Sidewalk restoration on the south side of Wellington Street E between Church Street and Scott Street will continue until Friday January 27th The City contractor will be demobilizing from the site by January 31st. Construction activities will resume in spring 2023, future updates will be provided once restart dates are determined.
Thank you for your patience during construction.
From this morning.
They are working on the sidewalk behind this view.
Thank you Mother Nature!
I wonder if the contractor is happy or pissed with this nice weather?
Who would have thought they would be working into the third week in January?
From tonight.
In 7-10 days and we might be at the Firkin bar/window getting dog treats again.
From yesterday
Scott St between Front and The Esplanade. Water and sewer replacement.
The water main is done and now they are working on the new sanitary sewer. They will be micro-tunnelling between the two new 9m deep shafts located on Scott Street.
Interesting how they form the shaft wall above ground and then I assume excavate from inside & below and then drop the wall and then repeat.
Scheduled for End of May completion. Some communication information from TYLin contractor.
Very interesting, l assume the sewer work here is unusually complex due to the sewage pumping station below Meridian Hall. I have never seen this elsewhere.
~2013
“The City has a long-term plan to replace the pumping station with a large diameter, deep, gravity relief sewer to service the area. However, until the new sewer is constructed, the City needed to increase the pumping station’s capacity to accommodate population growth in the immediate service area.”
I’m assuming this current work is part of the new gravity relief sewer system.
From last Tuesday.
The first section of the north shaft was excavated and poured.
From Friday. The 2nd formed section was completed
Friday
Removing fill with the excavator and bucket.
I asked one of the workers how they were loading the bucket?
… scroll down a little more
From tonight;
The concrete cylinder was lowered a few feet today. It doesn’t look level. Hopefully it doesn’t get jammed.:)
Mini me was digging the hole from the inside
Meanwhile over on Wellington St. E The Firkin Sidewalk is almost done.
February 6, 2023
RE: Wellington Street Construction
Due to favorable weather conditions, our contractor has been able to continue completing the permanent sidewalk work on the south side of Wellington Street E. The contractor has projected that they will be able to continue working in the area until the week of Feb 15th if favorable weather continues.
Completion of the south sidewalk on Wellington St E will reduce the amount of construction scheduled to be completed in the spring. Future updates will be provided once end and restart dates are determined.
