dunkalunk
there is only 4 stops on University.
There are 5 stops
![LQE2129.jpg](http://i.imgur.com/LQE2129.jpg)
There are 5 stops
Trains terminated at St. George until the line was extended past there, up Spadina and all the way to Wilson in 1978.I'd hope the reason it was called the University Subway is obvious to most of us. The 1963 University Subway extension started at Union and terminated at St. George. The majority of the route ran under University Avenue, hence the name University.
When the Bloor-Danforth line opened in 1966, remember that there were Yonge-University-Bloor and Yonge-University-Danforth trains in addition to the Bloor-Danforth trains.
So the University part of the name was briefly essential. However, this time has long-since passed, the triple-barrel name should be simplified.
Just do like the Bakerloo in London and call that side the Spadinaversity line.
but there are only 2 stops on Spadina Road.
Go back a few pages, the naming was related to the Spadina Expressway, not Spadina Road.
We should just use the number names the TTC rolled out. The 1 line is wonderfully simple and easy. The TTC will need to destroy all references to the old names if this scheme is to work. The lines aren't going to follow one street as they get expanded, except possibly for the Yonge alignment of the 1. We've known that since the Spadina line opened in the 1970s. The name "Spadina line" only makes sense if you know the history of the Spadina Expressway, which is becoming increasingly esoteric.
Naming lines after a street seems dated and parochial. It limits how we think about line extensions--that they have to keep following one street, or we're doing something wrong or unconventional. The simple number names will probably encourage planners to come up with more flexible and sophisticated alignments than those limited to following one street.
Moving in a diagonal line through an area is generally faster than if you have to follow two perpendicular lines. A line that doesn't follow a single road could more efficiently connect the high density areas that are scattered around the city. Line 2 leaves the Danforth to serve Crescent Town, for instance--a neighbourhood with higher density than what one finds on the Danforth in the area.
