Hi bloomingsmurf,
For your issues, I have some suggestions if you haven't try so.
1. Tony told me that the hot water isn't hot because there aren't a lot of people living in there yet, so the cold pipe would make it cooler than it should be, unless you let it run long enough for the hot water to heat up the pipe goes from source to your unit. I think he mentioned to let it run for 5-10 minutes to get hot enough water.
2. The outlet have some protective covering, it is intented to protect child from using metalic object to poke inside, Tony did mention that you have to "push quite hard" to get it in. When you unplug it, the cover should come back to its original location.
3. Since you've moved in, I think you could go downstairs to talk to Tony see if he could give you a quick check and see if it is easy to fix.
4. I guess we can do nothing much about this, maybe just buy a plastic/silicon mat and use the drawer itself as a cutlery holder. I measure almost everything when I'm purchase anything for my new condo, cause I know space is limited. Try measure the size of the drawer, and then you can shop for cultery holder that fits in the drawer.
Have fun decorating and fill up your own condo!
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I know I will when I moved in
